This is great Pascal ! Thank you for your efforts. Installed on my iPad just now.
Technically, the 'About' page of the app should reflect the authorship of the WP 31S as per the users manual (pg 8). I believe it is missing Jonathan and myself.
Well done Pascal. It installed flawlessly on my iPhone 5. The display is nice and clear.
Thank you,
(03-14-2015 01:34 PM)Sanjeev Visvanatha Wrote: [ -> ]Technically, the 'About' page of the app should reflect the authorship of the WP 31S as per the users manual (pg 8). I believe it is missing Jonathan and myself.
Sorry about this. It will be fixed in the next release.
Fantastic ! Thank you so much.
Amazingly fast booting time: On in an instant
Bravo and thank you!
Installed on my iPhone 4S running IOS 8.2.
Great application!
Thank you!
Sylvain
A few remarks:
On my iPad mini, the help text does not fit in its window. It is truncated on the right.
The register view is using two digit addresses. On the 31S a single digit suffices.
Other than that it is a very useful calculator app!
(03-17-2015 11:56 AM)Marcus von Cube Wrote: [ -> ]On my iPad mini, the help text does not fit in its window. It is truncated on the right.
Curious. I also have an iPad mini, and don't have this problem. I'm still running iOS 7, and the app version is 1.2.
Let me guess: this a non retina iPad Mini?
(03-17-2015 11:56 AM)Marcus von Cube Wrote: [ -> ]The register view is using two digit addresses. On the 31S a single digit suffices.
I think the Qt version has the same problem: the code is the same as the WP34s. It should be easy to change.
(03-17-2015 06:08 PM)pascal_meheut Wrote: [ -> ] (03-17-2015 11:56 AM)Marcus von Cube Wrote: [ -> ]On my iPad mini, the help text does not fit in its window. It is truncated on the right.
Your guess is 100% correct. The font scaling seems to be a bit different on this oldie.
(03-17-2015 09:09 PM)Marcus von Cube Wrote: [ -> ] (03-17-2015 06:08 PM)pascal_meheut Wrote: [ -> ]Let me guess: this a non retina iPad Mini?
My iPad mini is non-retina as well, but it does not exhibit this problem.
It seems the difference comes from iOS version. They changed popups behavior so I'm working on it.
(03-18-2015 05:17 AM)pascal_meheut Wrote: [ -> ]It seems the difference comes from iOS version. They changed popups behavior so I'm working on it.
Just make sure it still works properly on iOS 7 when you're done. I don't want to update to iOS 8.
I will. The question is whether to support iOS 6 & 5 or not.
New versions of the WP-31s and WP-34s emulators should be available soon on the App Store and should fix the help formatting problem as well as the 31s credits.
