Here's an example of how to create dynamic local variables:
locvars:={};
locname:={};
NEWLOC();
LSTO();
LRCL();
LSTON();
LRCLN();
EXPORT DYNLOC()
// an example
local mylocal;
mylocal:=1;
NEWLOC("cool",0);
LSTO("cool",-5);
NEWLOC("alist",1);
LSTO("alist",{1,2,3});
mylocal:=LRCL("cool")*3;
LRCL("alist")*mylocal+LRCLN("alist",1);
// name is a string
// vtype = 0 --> atomic;
NEWLOC(name,vtype)
local j;
j:=POS(locname,name);
if vtype then
locvars(j):={0};
else
locvars(j):=0;
end;
locname(j):=name;
// name is a string
// val is the value to store
// n is the index (0 if atomic)
LSTON(name,val,n)
local j;
if j then
if n then
if n>size(locvars(j)) then
MSGBOX("Invalid index: " + name + "(" + n + ")");
kill;
end;
locvars(j,n):=val;
else
locvars(j):=val;
end;
else
MSGBOX("Error: no such local var (" + name + ")");
kill;
end;
// name is a string
LRCLN(name,n)
local j;
if j then
if n then
MSGBOX("Invalid index " + name + "(" + n + ")");
kill;
end;
return(locvars(j,n));
else
return(locvars(j));
end;
else
kill;
end;
LSTO(name,val)
local j;
if j then
locvars(j):=val;
else
kill;
end;
LRCL(name)
local j;
if j then
return(locvars(j));
else
kill;
end;
Explanation to come a bit later; heading home from work.
thanks Han,
another bookmark for my "study soon the Prime programming" folder
(03-13-2015 07:59 PM)Han Wrote: [ -> ]Here's an example of how to create dynamic local variables:
locvars:={};
locname:={};
NEWLOC();
LSTO();
LRCL();
LSTON();
LRCLN();
EXPORT DYNLOC()
// an example
local mylocal;
mylocal:=1;
NEWLOC("cool",0);
LSTO("cool",-5);
NEWLOC("alist",1);
// name is a string
NEWLOC(name,vtype)
local j;
if vtype then
locvars(j):={0};
else
locvars(j):=0;
end;
locname(j):=name;
// name is a string
LSTON(name,val,n)
local j;
if j then
if n then
kill;
end;
locvars(j,n):=val;
else
locvars(j):=val;
end;
else
kill;
end;
// name is a string
LRCLN(name,n)
local j;
if j then
if n then
kill;
end;
else
return(locvars(j));
end;
else
kill;
end;
LSTO(name,val)
local j;
if j then
locvars(j):=val;
else
kill;
end;
LRCL(name)
local j;
if j then
return(locvars(j));
else
kill;
end;
And for the explanation:
Normally, one must declare all variables prior to their use. In this template, one only has to declare two generic container variables: localvars and localname. The variable localvars stores the values of the variables whereas localname stores their ascii names. We use localname as a lookup table to determine the index to use within localvars get the corresponding value.
NEWLOC("varname", type) -- creates a variable with name "varname" and initializes it to either 0 or {0} depending on whether type is 0 or non-zero (atomic versus composite variable). Thus, to create a list, one could do: NEWLOC("mylist",1). If that variable already exists, then it is reset. If not, then it is created as a new entry in both localvars and localname.
LSTO("varname",value) -- stores a value into "varname"
LSTON("varname", value, index) -- stores a value into the n-th position in a composite variable "varname". For example, LSTON("mylist",-3,5) is equivalent to mylist(5):=-3
LRCL and LRCLN behave similarly but recalls the value stored in the local variables.
locvars:={};
locname:={};
NEWLOC();
LSTO();
LRCL();
LSTON();
LRCLN();
EXPORT DYNLOC()
// an example
local mylocal;
mylocal:=1;
NEWLOC("cool",0);
LSTO("cool",-5);
NEWLOC("alist",1);
// name is a string
NEWLOC(name,vtype)
local j;
if vtype then
locvars(j):={0};
else
locvars(j):=0;
end;
locname(j):=name;
// name is a string
LSTON(name,val,n)
local j;
if j then
if n then
kill;
end;
locvars(j,n):=val;
else
locvars(j):=val;
end;
else
kill;
end;
// name is a string
LRCLN(name,n)
local j;
if j then
if n then
kill;
end;
else
return(locvars(j));
end;
else
kill;
end;
LSTO(name,val)
local j;
if j then
locvars(j):=val;
else
kill;
end;
LRCL(name)
local j;
if j then
return(locvars(j));
else
kill;
end;
(03-15-2015 07:44 PM)Han Wrote: [ -> ] (03-13-2015 07:59 PM)Han Wrote: [ -> ]Here's an example of how to create dynamic local variables:
locvars:={};
locname:={};
NEWLOC();
LSTO();
LRCL();
LSTON();
LRCLN();
EXPORT DYNLOC()
// an example
local mylocal;
mylocal:=1;
NEWLOC("cool",0);
LSTO("cool",-5);
NEWLOC("alist",1);
// name is a string
NEWLOC(name,vtype)
local j;
if vtype then
locvars(j):={0};
else
locvars(j):=0;
end;
locname(j):=name;
// name is a string
LSTON(name,val,n)
local j;
if j then
if n then
kill;
end;
locvars(j,n):=val;
else
locvars(j):=val;
end;
else
kill;
end;
// name is a string
LRCLN(name,n)
local j;
if j then
if n then
kill;
end;
else
return(locvars(j));
end;
else
kill;
end;
LSTO(name,val)
local j;
if j then
locvars(j):=val;
else
kill;
end;
LRCL(name)
local j;
if j then
return(locvars(j));
else
kill;
end;
this does not run on HPG2 why.
(05-19-2019 08:35 PM)tom234 Wrote: [ -> ] (03-13-2015 07:59 PM)Han Wrote: [ -> ]Here's an example of how to create dynamic local variables:
(code removed for legibility)
(03-15-2015 07:44 PM)Han Wrote: [ -> ]And for the explanation:
What issues did you run into? Were there any error messages at all?
