hi all,
I want to analyze this table with Statistic 2 var:
x_i: 1, 4, 6, 16
y_i: 41, 69, 82, 84
n_i: 4, 5, 6, 5 (practically: 20 tests divided into 4 groups)
I wouldn't write every item more times.
I should get regression parameters...
Any help, please?
Thanks in advance!
Salvo
I'd write a little utility program, something like this:
EXPORT UTIL1()
LOCAL k,j,n,m;
n:=SIZE(C3); // frequencies in C3
FOR m FROM 1 TO n DO
k:=C3(m);
FOR j FROM 1 TO k-1 DO
C1:=CONCAT(C1,C1(m)); // x_i in C1
C2:=CONCAT(C2,C2(m)); // y_i in C2
and then analyze the data {C1, C2} in the stat 2var app.
(03-06-2015 08:42 PM)Helge Gabert Wrote: [ -> ]I'd write a little utility program, something like this:
EXPORT UTIL1()
thank you!
it works... only two little typo (parenthesis closed at the end of concat() function:
EXPORT UTIL1()
LOCAL k,j,n,m;
k:=C3(m);
We could also add a function to reset data to only those with frequencies, to restart analysis...
However it's ok also so.
Thanks again
Thanks for the typo correction!
