01-05-2014, 01:32 PM
From an idea from HP48G
// Version 0.1
// Lars Fredriksson
// 2013-2014
LOCAL rows,cols;
DRAW();
MOVE();
CHECK_BOMBS();
CHK();
EXPORT Minehunt()
LOCAL Key,Pos:=1,Tmp,Bombs,Moves:=0;
rows:=10;
cols:=14;
L0:=SORT(MAKELIST(RANDINT(rows*cols-3)+2,X,1,rows*cols*.2)); // make some bombs ca 20%
L1:=MAKELIST(0,X,1,rows*cols); // make board
L1(1):=1;
RECT_P();
Tmp:=Pos; //REMEMBER POS
Bombs:=CHECK_BOMBS(Pos);
DRAW(Pos,Bombs,0,"Bombs "+Bombs +" Moves "+Moves); // Draw board
REPEAT
FREEZE;
Key:=WAIT();
Pos:=MOVE(Key,Pos); // make a move
L1(Pos):=1;
//Have we moved
IF Tmp≠Pos THEN
Moves:=Moves+1;
// Check if we step on a bomb
IF POS(L0,Pos)≠0 THEN
DRAW(Pos,Bombs,1,"Sorry, you step on a bomb after "+Moves+" moves"); // draw board and reveal bombs
WAIT(−1);
BREAK;
// check if we get to the goal
IF Pos==rows*cols THEN
DRAW(Pos,Bombs,1,"Congratulations, you made it in "+Moves+" moves");
WAIT(−1);
BREAK;
DRAW(Pos,Bombs,0,"Bombs "+Bombs +" Moves "+Moves); // redraw board
UNTIL Key==4; //ESC
CHECK_BOMBS(P)
LOCAL Count:=0;
LOCAL LE:=0,RE:=0; // EDGE
IF P MOD cols == 1 THEN
LE:=1;
IF P MOD cols == 0 THEN
RE:=1;
// count bombs in the neigbourhood
IF LE==0 THEN
Count:=Count+(POS(L0,CHK(P,P-cols-1))>0); //7
Count:=Count+(POS(L0,CHK(P,P-1))>0); //4
Count:=Count+(POS(L0,CHK(P,P+cols-1))>0); //1
Count:=Count+(POS(L0,CHK(P,P-cols))>0); //8
Count:=Count+(POS(L0,CHK(P,P+cols))>0); //2
IF RE==0 THEN
Count:=Count+(POS(L0,CHK(P,P-cols+1))>0); //9
Count:=Count+(POS(L0,CHK(P,P+1))>0); //6
Count:=Count+(POS(L0,CHK(P,P+cols+1))>0); //3
RETURN Count;
CHK(T,A)
IF A<1 THEN
RETURN T;
ELSE
RETURN A;
DRAW(P,B,S,T)
LOCAL X,Y,X1,X2,Y1,Y2,C:=1;
// calculate size of boxes
X0:=IP(320/(cols+2));
Y0:=IP(240/(rows+2));
X1:=IP(320/(cols+2));
Y1:=IP(240/(rows+2));
RECT_P(0,0,320,Y1,RGB(255,255,255),RGB(255,255,255));
FOR Y:=1 TO rows DO
FOR X:=1 TO cols DO
IF L1(C)==1 THEN
IF C==P THEN
RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(128,255,128));
ELSE
RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(255,255,255));
ELSE
RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(180,180,180));
IF S == 1 THEN //SHOW BOMBS
IF POS(L0,C)≠0 THEN
IF C==P THEN
RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(255,0,0));
ELSE
RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(255,180,180));
C:=C+1;
TEXTOUT_P(T,10,5);
//BLIT_P(G1);
MOVE(KEY,P)
LE:=1;
RE:=1;
CASE
IF KEY==32 THEN //7
IF P-cols-1 >= 0 THEN
IF LE==0 THEN
P:=P-cols-1;
IF KEY==33 THEN //8
IF P-cols >= 0 THEN
P:=P-cols;
IF KEY==34 THEN // 9
IF P-cols+1 >= 0 THEN
IF RE==0 THEN
P:=P-cols+1;
IF KEY==37 THEN //4
IF P-1 >= 0 THEN
IF LE==0 THEN
P:=P-1;
IF KEY==39 THEN //6
IF P+1 ≤ rows*cols THEN
IF RE==0 THEN
P:=P+1;
IF KEY==42 THEN //1
IF P+cols-1 < rows*cols THEN
IF LE==0 THEN
P:=P+cols-1;
IF KEY==43 THEN //2
IF P+cols ≤ rows*cols THEN
P:=P+cols;
IF KEY==44 THEN //3
IF P+cols+1 ≤ rows*cols THEN
IF RE==0 THEN
P:=P+cols+1;
DEFAULT
RETURN P;
