If my 4-level stack on my 12c contains:
t - don't care
z - don't care
y - 17
x - 5
and I want it to contain:
t - 17
z - 5
y - 17
x - 5
is there an elegant way to achieve that using only ENTER, roll down, and x<->y?
(03-02-2015 03:18 AM)Don Shepherd Wrote: [ -> ]If my 4-level stack on my 12c contains:
t - don't care
z - don't care
y - 17
x - 5
t - 17
z - 5
y - 17
x - 5
If you also allow Rup it can be done in six steps:
Enter, Enter, Rup, Enter, Rdn, x<>y
t 0 0 17 5 5 17 17
z 0 17 5 5 5 5 5
y 17 5 5 5 17 5 17
x 5 5 5 17 17 17 5
The Rup can be replaced with three Rdn for a total of eight steps:
Enter, Enter, Rdn, Rdn, Rdn, Enter, Rdn, x<>y
t 0 0 17 5 5 5 5 17 17
z 0 17 5 17 5 5 5 5 5
y 17 5 5 5 17 5 17 5 17
x 5 5 5 5 5 17 17 17 5
I'm sure someone can do better.
I'm sure someone will find an 'elegant' way in fewer steps, but:
17
5 Enter ^
17
5
5 Enter ^
17
5
5
5 R v
5
17
5
5 R v
5
5
17
5 R v
5
5
5
17 Enter ^
5
5
17
17 R v
17
5
5
17 x <> y
17
5
17
5 Task complete
Total 8 operations.
Yep, somebody will definitely find a shorter one. But at least this is straightforward. ;-)
Dale
Mark,
I guess us old HP-25 users think similarly... and simultaneously! It may chew up 8 steps, but at least it's easy to remember. Repeat after me:
"Enter - Enter - Down Down Down - Enter - Down - Exchange"
t - don't care
z - don't care
y - 17
x - 5
t - 17
z - 5
y - 17
x - 5
t z x x y x z z x y y
z y z z x y x x x x x
y x y x z x y x y x y
x x x y x z x y y y x
Perhaps not the fastest approach, but it was asked to be elegant!
Bernhard
(03-02-2015 03:50 AM)Dale Reed Wrote: [ -> ]Mark,
I would say that great minds think alike.
In fewer keystrokes but not sticking to the operations available:
Assuming that: 17 ENTER 5 has already occurred.
Then:
Pauli
t - don't care
z - don't care
y - 17
x - 5
t - 17
z - 5
y - 17
x - 5
Sigma+
RCL 2
RCL 4
RCL 2
But it does not count (...too many preconditions).
(03-02-2015 08:19 AM)Csaba Tizedes Wrote: [ -> ]But it does not count (...too many preconditions).
If preconditions are allowed:
RCL 0 (R0 contains 17)
RCL 1 (R1 contains 5)
Shortest key sequence with preconditions allowed:
R/S
(03-02-2015 10:48 AM)PANAMATIK Wrote: [ -> ] (03-02-2015 08:19 AM)Csaba Tizedes Wrote: [ -> ]But it does not count (...too many preconditions).
R/S
Stretching the preconditions a bith further and assuming 17 and 5 are on the stack:
2dup
... hp71b in forth mode.
6 steps:
ENTER
ENTER
RDN
X<>Y
LASTX
Cheers, Werner
(03-02-2015 03:18 AM)Don Shepherd Wrote: [ -> ]is there an elegant way to achieve that using only ENTER, roll down, and x<->y?
The attached file contains all the possible stack manipulation.
From the french book "Programmer HP-41"
(03-02-2015 12:28 PM)Werner Wrote: [ -> ]6 steps:
ENTER
ENTER
RDN
X<>Y
LASTX
Cheers, Werner
Yes, this is REALLY elegant! Grat!
ENTER
ENTER
RDN
X<>Y
LASTX
Cheers, Werner
Well, I have to agree with Csaba. Elegant!
I hadn't thought about LastX, I admit, but you sure made good use of that function in this case.
Thanks to all. Lots of great minds out there.
Don
Tony Hutchins gave this 7-step solution without using LASTX.
ENTER
ENTER
CLx
Roll Down
X<>Y
Roll Down
But more importantly, the PDF where this and a large number of such ideas is found here:
Stack Rearrangements
You can find this solution by searching for ABAB, which represents XYXY as the contents of the four level RPN stack.
Thanks Gene. A fascinating book.
I just realized I have the book upon which Tony's book is based, "Algorithms for RPN Calculators," in my bookcase!
But I wouldn't have known about Werner's 6-step solution from that book, I suppose.
Don
(03-02-2015 03:30 PM)Gene Wrote: [ -> ]Stack Rearrangements
That's why we have included the shuffle command ⇄ in the 34S. It allows to shuffle the lower four stack levels in an arbitrary fashion with a single command. The main purpose of this command is readability in a program but it works interactively as well. To accomplish the requested task the command would be:
Self explanatory, isn't it?
A solution that works for all calculators which can directly recall the stack:
When I saw the discussion of management of operational scale I remembered a paper from Tony Hutching where the author presents a series of tables to relocate data (see attached). Perhaps it would be useful to analyze this issue
I take this opportunity to ask for a brief management explanation of Tony job and if it is useful today for programming the HP 35s calculator. Thank you very much for your attention, Pedro
(03-03-2015 11:25 PM)PedroLeiva Wrote: [ -> ]When I saw the discussion of management of operational scale I remembered a paper from Tony Hutching where the author presents a series of tables to relocate data (see attached). Perhaps it would be useful to analyze this issue
Same as
Gene's.
(03-04-2015 06:52 AM)Massimo Gnerucci Wrote: [ -> ] (03-03-2015 11:25 PM)PedroLeiva Wrote: [ -> ]When I saw the discussion of management of operational scale I remembered a paper from Tony Hutching where the author presents a series of tables to relocate data (see attached). Perhaps it would be useful to analyze this issue
Same as Gene's.
My apologies. I read over what Gene had written, and did not open the file. Sorry. But I still wonder if Tony tables are useful today, and what is the reason of saving so much programming steps. Pedro
