01-04-2014, 11:04 PM
a first attempt in trying to create an equation library for the Prime.
It has a lot of limitations.
If you want to test it please create two lists:
EQLIB:={"S=A*B", "S=A*B/2"}
EQLIBNAME:={"Surface of a rectangle", "Surface of a triangle"}
I created these list names just to prevent overwriting the L0-L9 by mistake.
Anyway it was a good example for me to launch/use APPS like the SOLVE from the HPPL.
As you can see i commented the REPEAT..UNTIL loop because there is no HALT..CONTINUE command like in the 48. When the solve APP is launched, the program doesn't stop showing a new session of CHOOSE before giving you the time to solve for a variable. Maybe here a GETKEY could do the trick.
The other limitation is that i used only A...Z variables in order to avoid to declare the variable prior to RUN the program. There should be a way to retrieve a list of variables from a equation but i still didn't find it.
Please suggest how i could improve it. I am sure it can be improved.
Thanks
Giancarlo
EXPORT PSOLVE()
LOCAL A,B,C:="",D:="";
// REPEAT
CHOOSE(B,"SOLVE EQ LIBRARY","SOLVE AN EQUATION","ADD AN EQUATION","EXIT");
CASE
IF B=1 THEN
CHOOSE(A,"SOLVE EQ LIB", EQLIBNAME);
E1:= EQLIB(A);
STARTAPP("Solve");
CHECK(1);
UNCHECK(2);
UNCHECK(3);
UNCHECK(4);
UNCHECK(5);
UNCHECK(6);
UNCHECK(7);
UNCHECK(8);
UNCHECK(9);
UNCHECK(0);
STARTVIEW(2,0);
IF B=2 THEN
INPUT({C,D},"INSERT AN EQ",{"EQ: ","EQ NAME:"},{"INSERT AN EQ. AS A STRING","INSERT AN EQ. NAME AS A STRING"});
EQLIBNAME(0):=D;
EQLIB(0):=C;
//UNTIL B=3;
Thanks
Giancarlo
