02-22-2015, 09:42 PM
The program RLCSERIES and RLCPAREL calculate:
• The total impedance of the circuit, and its magnitude in ohms
• Phase angle in a circuit in degrees.
• Current of the series in amps.
RLCSERIES works with series circuits while RLCPAREL works with parallel circuits.
Input:
Battery/Source: enter voltage and frequency
Add as many resistors (R) (in Ohms Ω), capacitors (C) (in farad), and inductors (L) (in henrys) as needed. On the input screen, enter the real (a) and imaginary (if needed) (bi) parts separately.
Example - Series Circuit:
Series circuit powered by a 14 V, 5000 Hz battery. The circuit has: a resistor of 100 Ω, a capacitor of 3.2*10^-6 farads, and an inductor of 0.082 henrys.
Results:
Total Resistance:
100 + 2566.158792*i
Magnitude:
2568.10649035
Phase Angle:
87.7683842611°
Current:
5.45148733225 * 10^-3
RLCSERIES: HP Prime
Example - Parallel Circuit:
Parallel circuit powered by a 14 V, 5000 Hz battery. The circuit has:
RLCPAREL: HP Prime
Sources:
ElectronicsTutorials. Series RLC Circuit Analysis URL: http://www.electronics-tutorials.ws/acci...rcuit.html
Retrieved February 22, 2015
ElectronicsTutorials. Parallel RLC Circuit Analysis URL:
Van Valkenburg, Mac E. (Editor) and Wendy M. Middelton (Editor) "Reference Data for Engineers: Radio, Electronics, Computer, and Communications" 9th Edition. Newnes, Butterworth-Heinemann: Wolburn, MA 2002. Print.
Input:
Results:
Total Resistance:
100 + 2566.158792*i
Magnitude:
2568.10649035
Phase Angle:
87.7683842611°
Current:
RLCSERIES: HP Prime
// Impedance of a Series
// EWS 2015-02-22
// Turn allow complex from real input on
// Declare subroutines
chsubr();
casubr();
// Main Routine
EXPORT RLCSERIES()
// initial steps
Z0:=0;
// radian mode
HAngle:=0;
// counter
I:=0;
// battery information
INPUT({V,F},"Battery Information",
{"V = ","F = "},
{"Volts","Frequency (Hz)"});
chsubr();
// Choose Subroutine
chsubr()
LOCAL ch;
CHOOSE(ch,"# of Components: "+STRING(I),
{"Add Resistor (R)",
"Add Capacitor (C)",
"Add Inductor (L)",
"Calculate"});
// Execute calculation subroutine
casubr(ch);
// Calculation Subroutine
casubr(x)
IF x==1 THEN
INPUT(R,"Add Resistor","R =",
// EWS 2015-02-22
chsubr();
casubr();
// Main Routine
EXPORT RLCSERIES()
// initial steps
Z0:=0;
// radian mode
HAngle:=0;
// counter
I:=0;
{"V = ","F = "},
chsubr();
chsubr()
LOCAL ch;
"Add Inductor (L)",
"Calculate"});
casubr(ch);
casubr(x)
LOCAL a,b;
IF x==1 THEN
INPUT({a,b},"Resistor (Ω)",
{"a =","bi="});
Z0:=Z0+(a+b*i);
I:=I+1;
chsubr();
IF x==2 THEN
INPUT({a,b},"Capacitor (farad)",
{"a =","bi="});
Z0:=Z0-i/(2*π*F*(a+b*i));
I:=I+1;
chsubr();
IF x==3 THEN
INPUT({a,b},"Inductor (henry)",
{"a =","bi="});
Z0:=Z0+i*2*π*F*(a+b*i);
I:=I+1;
chsubr();
// Calculation
IF x==4 THEN
PRINT();
PRINT("Impedance = "+Z0);
PRINT("Magnitude (Ω) = "+ABS(Z0));
PRINT("Phase Angle (°) ="+
STRING(ARG(Z0)*180/π));
PRINT("Current (amps) = "+
STRING(V/ABS(Z0)));
RETURN Z0;
RLCPAREL: HP Prime
// Impedance of a Parallel
// EWS 2015-02-22
chsubr();
casubr();
// Main Routine
EXPORT RLCPAREL()
// initial steps
Z0:=0;
// radian mode
HAngle:=0;
// counter
I:=0;
{"V = ","F = "},
chsubr();
chsubr()
LOCAL ch;
"Add Inductor (L)",
"Calculate"});
casubr(ch);
casubr(x)
LOCAL a,b;
IF x==1 THEN
INPUT({a,b},"Add Resistor (Ω)",
{"a =","bi ="});
Z0:=Z0+1/(a+b*i);
I:=I+1;
chsubr();
IF x==2 THEN
{"a =","bi="});
Z0:=Z0-1/(i/(2*π*F*(a+b*i)));
I:=I+1;
chsubr();
IF x==3 THEN
{"a =","bi="});
Z0:=Z0+1/(i*2*π*F*(a+b*i));
I:=I+1;
chsubr();
// Termination
IF x==4 THEN
Z0:=1/Z0;
PRINT();
PRINT("Total Resistance = "+Z0);
STRING(−ARG(Z0)*180/π));
STRING(V/ABS(Z0)));
RETURN Z0;
Sources:
