(04-09-2015 08:35 PM)walter b Wrote: [ -> ]Just try the Manual Calculation Guide published here. Any difficulties reading it? With whatever OS you have?
d:-)
Thanks Walter, I downloaded your Manual Calculation Guide, and it is viewable in Linux with standard PDF viewers.
(04-09-2015 05:59 PM)walter b Wrote: [ -> ]What kind of problems do you expect?
Depending on what software you are using, some generator are using extensions not compatible with other PDF reader.
I have often seen this with data entry PDF files.
(04-09-2015 11:36 PM)BarryMead Wrote: [ -> ]Thanks Walter, I downloaded your Manual Calculation Guide, and it is viewable in Linux with standard PDF viewers.
Same here on OSX v10.10.3 with OSX Preview, Acrobat Reader and with PDFPenPro.
Sylvain
