The HP-65 does base conversions between decimal and octal only.
Convert octal 11 to decimal, and it becomes 9, of course.
What other number will also convert to decimal 9?
In octal or another base?
10 base 9 does. (and yes a big :-) here!)
Hope you are doing well Don!
(02-20-2015 02:17 PM)Gene Wrote: [ -> ]In octal or another base?
Hey Gene, Nashville man, good to hear. It's cold up here in Looeyville, but I suppose it's the same in Nashville with this crazy winter weather.
If you do octal --> decimal on the HP-65, 11 gives 9. What other number would give 9 on an octal --> decimal conversion?
(02-20-2015 03:34 PM)Don Shepherd Wrote: [ -> ]If you do octal --> decimal on the HP-65, 11 gives 9. What other number would give 9 on an octal --> decimal conversion?
9, per a special HP-65 "feature" you mentioned
here a few years ago.
Gerson.
(02-20-2015 05:35 PM)Gerson W. Barbosa Wrote: [ -> ] (02-20-2015 03:34 PM)Don Shepherd Wrote: [ -> ]If you do octal --> decimal on the HP-65, 11 gives 9. What other number would give 9 on an octal --> decimal conversion?
9, per a special HP-65 "feature" you mentioned here a few years ago.
Gerson.
Yes, you remembered that Gerson. I still marvel over that "feature" and have wondered now and then how that happened.
Can it be that simply there wasn't enough space left for an error handling?
Quote:As an additional feature, the "octal to decimal" conversion will accept non-octal arguments containing the digits 8 or 9. A non-octal number such as 998 will be interpreted as (9x82) + (9x8) + 8 = 656.
I would have expected 1220.
Seriously, this is a bit misleading, probably the reason why later on the 35s the use of a suffix like 'h' or 'o' was made mandatory to the detriment of a certain ease of use. I remember the prime was also quite painful. I wish I had had a 16c.
(02-20-2015 06:52 PM)Thomas Radtke Wrote: [ -> ]Can it be that simply there wasn't enough space left for an error handling?
That's probably the most likely explanation, Thomas. The 65 has no alpha display capability, so normal error messages are not possible. Instead, the display blinks when an error such as divide by 0 or square root of a negative number occurs. It would have required more microcode to check an "octal" number for erroneous digits 8 or 9, and they probably just didn't have the space.
So they documented it and called it a "feature."
(02-20-2015 06:56 PM)Tugdual Wrote: [ -> ]Quote:As an additional feature, the "octal to decimal" conversion will accept non-octal arguments containing the digits 8 or 9. A non-octal number such as 998 will be interpreted as (9x82) + (9x8) + 8 = 656.
The 41C had the same OCT and DEC feature but, at least, handles exceptions and throws a DATA ERROR.
(02-20-2015 06:56 PM)Tugdual Wrote: [ -> ]I would have expected 1220.
How would you end up with this result?
998
o
[f-1] [→OCT]
656
d
[f] [→OCT]
1220
o
(02-20-2015 08:09 PM)Thomas Klemm Wrote: [ -> ]How would you end up with this result?
998o
[f-1] [→OCT]
656d
[f] [→OCT]
1220o
Oh so you mean the calculator is converting but doesn't actually have a different base system?
998
o
ENTER↑
1220
o
(02-20-2015 08:15 PM)Tugdual Wrote: [ -> ]Oh so you mean the calculator is converting but doesn't actually have a different base system?
It's like using these two programs:
998
→DEC
→OCT
00 { 36-Byte Prgm } 00 { 35-Byte Prgm }
01>LBL "->DEC" 01>LBL "->OCT"
02 STO 00 02 STO 00
03 -2 03 2
04 X<>Y 04 X<>Y
05>LBL 00 05>LBL 00
06 8 06 10
07 X<>Y 07 X<>Y
08 10 08 8
09 ÷ 09 ÷
10 IP 10 IP
11 X=0? 11 X=0?
12 GTO 01 12 GTO 01
13 Rv 13 Rv
14 × 14 ×
15 Rv 15 Rv
16 × 16 ×
17 STO+ 00 17 STO+ 00
18 Rv 18 Rv
19 GTO 00 19 GTO 00
20>LBL 01 20>LBL 01
21 RCL 00 21 RCL 00
22 END 22 END
