(02-19-2015 11:58 AM)Offroad Wrote: [ -> ]You could make an app yourself in the meantime if you need them that much. It's part of the fun of owing a Prime. At the end you'll have your very own customized high performance calculator that meets all your needs.
Offroad
yes, you're right!
I love my Prime...
Let's go, but, please, help me to find errors, improve the programs and simplify them
Logistic distribution
EXPORT logisticd(m,s,k)
// Logistic distribution m=μ location , s=σ >0 scale, k=x var
local f,g;
IF s<=0 THEN RETURN("Use: m, s>0, k"); END;
g:= (k-m)/s;
f:=e^(-g)/(s*(1+e^(-g))^2) ;
return f;
EXPORT logistic_cdf(m,s,k)
local f,g;
g:= (k-m)/s;
f := 1/(1+e^(-g));
return f;
END ;
EXPORT logisticd_icdf(m,s,p)
// inverse m=μ, s=σ, p probability
local f;
IF s<=0 THEN RETURN("Use: m, s>0, p"); END;
f:= m+s*ln(p/(1-p));
return f;
Lognormal
EXPORT LgNrm(m,s,k)
// LogNormal distribution m=μ, s=σ>0 shape, k=x var
local f;
f:= piecewise(k<=0,0, (1/(k*s*sqrt(2*pi)))*e^(-(ln(k)-m)^2/(2*s^2)));
return f;
EXPORT LgNrm_cdf(m,s,k)
// LgNrm(m,s,k) = normal((ln(k)-m)/s) - normal(k) = LgNrm(0,1,e^k)
local f;
f:=(1/2)+(1/2)*erf((ln(k)-m)/(sqrt(2)*s));
return f;
END ;
Exponential
EXPORT expond(l,n)
// exponential distribution l=λ=1/np, n
// expond(1/2, n) = chi2(2, n)
// expon(λ) = gammad2(1, 1/λ)
local f;
f:= piecewise(n<0,0, l*e^(-l*n));
return f;
EXPORT expond_cdf(l,n)
local f;
f := piecewise(n<0, 0, 1-e^(-l*n));
return f;
END ;
Geometric
EXPORT geometric(p, k)
// Geometric distribution, k trial, p probability (kth trial first success)
// geometric(p) = Negbinom(1,p)
local f;
IF k<1 THEN RETURN("k must be int >= 1"); END;
k:= IP(k);
f:= p*(1-p)^(k-1);
return f;
EXPORT geometric2(p, k)
// Geometric distribution, k trial, p probability (failure until 1st success)
local f;
IF k<0 THEN RETURN("k must be int >= 0"); END;
k:= IP(k);
f:= p*(1-p)^(k);
return f;
EXPORT geometric_cdf(p, k)
local f;
f := 1-(1-p)^k;
return f;
END ;
EXPORT geometric2_cdf(p, k)
local f;
f := 1-(1-p)^(k+1);
return f;
END ;
Hypergeometric and negative hypergeometric
EXPORT hypergeom(N, n, m, k)
// Hypergeometric distribution
// N population size, m (or K) #successes in population
// n number of draws (without replacement), k (or i) number of successes
local f;
f:= (comb(m,k)*comb(N-m,n-k))/(comb(N,n));
return f;
EXPORT negHypergeom(r, n, m, k)
// Negative Hypergeomtric distribution
// r nth special item, N=n+m, n special, m normal, k var
local f;
IF (k<r OR r<0 OR k<0) THEN RETURN("Use: (r, n, m, k) - k must be >= r"); END;
f:=(comb(n,r-1)*comb(m,k-r)/comb(n+m,k-1))*((n-r+1)/(n+m-k+1));
return f;
Negative Binomial
EXPORT NegBin(r, p,n)
// Negative Binomial distribution observing until r success, with p probability of success
// n num trials for r success (k failures), n=r, r+1,...
// negBinom(1,p) = geometric(p)
local f;
IF (n<r) THEN return "n must be >= r"; ELSE
f:= comb(n-1, r-1)*(p^r)*(1-p)^(n-r);
return f;
END; //if
EXPORT NegBin_cdf(r, p, n)
local f, b1, a, b;
a:=r; b:= n+1;
b1:= int((X^(a-1))*(1-X)^(b-1),X,0,p);
// incomplete beta function
f:=( b1/Beta(a,b));
return f;
EXPORT NegBin2(r, p,k)
// Negative Binomial observing until r failures, with p probability of success (1-p failure)
// n num trials, k = n-r success
// i.e. NegBin(5,0.4,15) = NegBin2(5,0.6,10)
local f;
f:= (comb(k+r-1,k))*(p^k)*((1-p)^r);
return f;
Gompertz
EXPORT gompertz(h,b,n)
// Gompertz distribution h=η shape param, b scale param, n var
local f;
IF (n<0 OR h<=0 OR b<=0) THEN return "Not defined for η or b < =0 or n <0"; ELSE
f:= b*h*e^(b*n)*e^h*e^(-h*e^(b*n)) ;
return f;
END; // if
EXPORT gompertz_cdf(h,b,n)
local f;
f := 1-e^(-h*(e^(b*n)-1));
return f;
END ;
My purpose is now standardize these programs also using the same variable naming of the others distributions in the Prime and make controls to suggest and guide the user input. Any help much appreciated!
I hope the programs could be helpful to whom use Prime for statistics.
Salvo
