02-22-2015, 06:28 PM
(02-22-2015 03:29 PM)John Galt Wrote: [ -> ](02-22-2015 02:05 PM)Csaba Tizedes Wrote: [ -> ]If possible to make a 34s from a 20B or 30B, therefore is it possible to make a 30b from a 20b? (30b ROM upload to the 20b)??
I suppose it's theoretically possible, but you would need the 30b's ROM code, which Marcus von Cube states is HP's intellectual property.
Well protected IP I must say. You can load the image in an HP 20b but it will stay an HP 20b. The 30b functions are not available. I assume there is some hidden trick to identify the actual hardware and disable certain features depending on it.
