02-09-2015, 10:38 PM
Hello !
Is there a way to directly plot functions obtained from CAS in the function app?
As an example, if I execute the CAS.tchebyshev(3) command in home to obtain a polynomial in X and copy the result in the function app, then it works.
When I insert CAS.tchebyshev(3) directly in the function app, it gives F1(X):NaN.
I took the Tchebyshev polynomials as an example, but it's the same for all functions you obtain from CAS command (fcoeff(),...).
reto
reto
