01-28-2015, 09:43 AM
Hello.
I was trying to fill a column with the "MAKE" command in Statistics 2 Var.
If I enter 1000 with the digit grouping set to 123'456.789 the entered value will be 1'000 and the app gives a syntax error.
Same problem with digit grouping set to
123,456.789
123 456.789
Same problem with the digital point set to "," if you enter a number like2,3
It seems to work fine only with the digit grouping to 123456.789
I have the same problem with the input of data in programs but only on the emulator.
reto
123,456.789
123 456.789
reto
