The 50g has the ARCHIVE command that backs up everything with one command, either internally or externally.
How does one do this with the Prime?
I see no way to archive ALL user variables.
Thanks in advance for any help.
Try the backup command in the connectivity kit. Not sure if it saves everything.
The connectivity kit, and libhpcalcs, support a backup operation, which makes the calculator send all of its programs, notes, real numbers, complex numbers, lists, matrices, settings (CAS and non-CAS, exam testing mode), and several other file types.
(01-01-2014 04:56 PM)debrouxl Wrote: [ -> ]The connectivity kit, and libhpcalcs, support a backup operation, which makes the calculator send all of its programs, notes, real numbers, complex numbers, lists, matrices, settings (CAS and non-CAS, exam testing mode), and several other file types.
It will not, however, save User variables and User defined functions.
