HP-12C Platinum keystrokes:
9
R/S
g GTO 090 R/S
g GTO 100 R/S
g GTO 178 R/S
g GTO 157 R/S
g GTO 137 R/S
HP-15C keystrokes:
9
SIN
COS
TAN
g TAN-¹
g COS-¹
g SIN-¹
More information and instructions
here.
Link to HP Emulators, including the HP 12c Virtual Calculator:
http://www.calculatrices-hp.com/index.ph...emulateurs (Thanks, Franz!)
Steps 277 through 399 are optional and can be deleted if necessary (in this case change line 268 to GTO 000).
12C_Platinum_Trigs.zip: Same as the US (THEM?:-) version, except that DECIMAL POINT IS COMMA.
(01-26-2015 09:07 AM)EdS2 Wrote: [ -> ]How do these trig functions compare to Valentin Albillo's?
(http://www.hpcc.org/datafile/hp12/12c_Tr...ctions.pdf)
Fast and Accurate Trigonometric Functions on the HP-12C Platinum
- Angle modes (DEG, RAD, GRAD);
- The stack register Y is preserved;
- Wider input range while keeping the same accuracy (SIN, COS, TAN: |x| < 1E12 degrees);
- All functions are computed independently;
- Mostly fixed execution times regardless of the arguments;
- More accurate results (mainly because the HP 12c Platinum doesn't round intermediate results to 10 digits);
- Faster method (Minimax polynomial rather than Taylor series);
- At least 276 steps long, plus 15 registers;
- It works on the HP 12c Platinum only.
Valentin was limited to only 99 steps however, so his achievement is quite remarkable. I wonder what he could have done with four times more programming steps! (He would never need that much, in the first place).
Gerson.
Thanks! Just the degrees mode could be a crucial advantage.
