01-25-2015, 09:12 AM
I've posted this for Thomas (previous discussion today) but others especially new to the 35s might be interested: Yet another R<>P conversion routine. I'll put the codes first, and then the explanation of usage thereafter. Like I told Thomas, it makes no claims, is trivial, WORKS, and is just one example. There are scads of these (kinda fun to collect them) which beg the question, "why does the HP35s get such a pounding because it doesn't have any easy decomposition routines for R<>P?" Here is the code:
To use to convert R<>P (default) place Y in y, and place X in x, press [XEQ] [P] [ENTER]
Leave the (-1) default parm for R<>P mode and press [R/S]
y will hold R, x will hold theta (phase angle)
To use to convert P<>R place R in y, place theta (angle) in x, press [XEQ] [P] [ENTER]
Change (-1) to (1) with the [+/-] key and press [R/S]
y will hold Y, x will hold X
Also, after running this routine X, Y, R, and Theta will be in registers respectively: X, Y, R, A
This thing can be optimized and altered by using complex numbers and [ABS] with [ARG].
Also, the hidden codes REGx and REGy might be useful.
This is just one way to solve this problem, is easy, works, and is almost trivial all things considered. So, it eliminates one negative irk of the HP35s for some users. I don't know.
Enjoy
P001 LBL P
P002 x<> F ; parameter for determining R<>P vs P<>R
P003 CLx
P004 -1 ; less than zero (default) R<>P X in x, Y in y
P005 STOP ; give the operator a chance to change the parm use [+/-] key
P006 x>0? ; branch around R<>P routine
P007 GTO P023
P008 x<> F
P009 STO X ; Entry Point for R<>P routine
P010 x^2 ; compute R value to be placed in y Y
P011 x<>y
P012 STO Y
P013 x^2
P014 +
P015 |x ; use square root key
P016 STO R ; save R to R
P017 RCL Y ; compute theta , R is lifted to y
P018 RCL X ;
P019 /
P020 ATAN
P021 STO A ; save theta in A (P y holds R, x holds theta
P022 RTN ; END R<>P routine
P023 x<> F ; Entry Point P<>R routine
P024 x<>y ; might have been able to use REGx REGy here...
P025 STO R ; save R from y
P026 x<>y ;
P027 STO A ; Save A (theta) from x
P028 SIN
P029 * ; multiply compute y
P030 STO Y
P031 RCL R ;
P032 RCL A ;
P033 COS
P034 * ; multiply compute x
P035 STO X
P036 RTN ; END P<>R routine y holds Y, x holds X
LN=110 CK=0E3B
Enjoy
