01-24-2015, 03:18 AM
Pages: 1 2
01-24-2015, 06:06 AM
(01-24-2015 03:18 AM)marcusnicolas1 Wrote: [ -> ]I read the book and tried convert 20.5 km to miles but I was not able to for some reason. Can anyone help me with this? ThanksIf you're in RPN mode, do this:
1. Type 20.5 (do NOT press Enter)
2. Press Shift then Units
3. Tap Units menu choice
4. Tap Length
5. Tap km (20.5_km will be displayed)
6. Press Enter
7. Put in 1_mi using same technique as steps 1 - 5.
8. Press Shift then Units
9. Tap Tools menu choice
10. Tap CONVERT menu choice
11. Display will read 12.7381094409_mile (depending on your decimal setting)
01-25-2015, 01:12 AM
There's a nifty shortcut. Just type this and press Enter:
In Home view: 20.5_km►_mile
In CAS view: 20.5_km►_mi
where ► is the "Sto" character (either Shift EEX or the [Sto►] menu button). Prime will add parentheses around the units automatically.
The fact that miles are called "mile" in Home and "mi" in CAS is a symptom of Prime's unfortunate dissociative identity disorder.
EDIT: Just noticed that CAS also allows "mile", but Home doesn't allow "mi". Humph.
01-25-2015, 03:57 AM
(01-25-2015 01:12 AM)Joe Horn Wrote: [ -> ]I can't make it work in RPN mode. I tried(01-24-2015 03:18 AM)marcusnicolas1 Wrote: [ -> ]I read the book and tried convert 20.5 km to miles but I was not able to for some reason. Can anyone help me with this? Thanks
20.5_km then pressing STO. I get bad argument count
I tried 20.5_km Enter
then type _mile and STO I get "Do you want to create a variable called ►_mile"
Tom Lake
01-25-2015, 04:28 AM
(01-25-2015 03:57 AM)toml_12953 Wrote: [ -> ](01-25-2015 01:12 AM)Joe Horn Wrote: [ -> ]There's a nifty shortcut. Just type this and press Enter:I can't make it work in RPN mode. I tried
Tom Lake
This shortcut works in Algebraic and Textbook modes only. Storage (using the STO ►method) in RPN works differently due to the way the stack works, whereby one must put the value to store onto the stack, then specify the target variable, then invoke the storage command.
02-01-2015, 02:59 AM
Thanks for the help. Now I have one more question. I tried adding 1cm to 5in and it will not give me an answer. I just keep getting an error code. The book tells me I should get an answer. Can anyone help me with this please? Thanks
02-01-2015, 06:02 AM
(02-01-2015 02:59 AM)marcusnicolas1 Wrote: [ -> ]Thanks for the help. Now I have one more question. I tried adding 1cm to 5in and it will not give me an answer. I just keep getting an error code. The book tells me I should get an answer. Can anyone help me with this please? Thanks
Depends on the mode you're in, and the quirk that inches are called "in" in Home, and "inch" in CAS.
Home in RPN Entry mode: 1_(cm) Enter 5_(in) +
Home in Textbook/Algebraic entry mode: 1_(cm)+5_(in) Enter
CAS in Algebraic Entry mode: 1_cm+5_inch Enter
CAS in Textbook Entry mode: 1_(cm)+5_(inch) Enter
CAS in RPN Entry mode acts like CAS in Algebraic Entry mode.
02-01-2015, 01:15 PM
(01-24-2015 06:06 AM)toml_12953 Wrote: [ -> ](01-24-2015 03:18 AM)marcusnicolas1 Wrote: [ -> ]I read the book and tried convert 20.5 km to miles but I was not able to for some reason. Can anyone help me with this? ThanksIf you're in RPN mode, do this:
4. Tap Length
6. Press Enter
At least one step less in RPN : Step 7 can be "7. Put in 1_mi using same technique as steps 2 - 5." If you choose the unit without giving a quantity first, 1 is assumed automatically by the calculator.
Cheers,
Miguel
02-03-2015, 09:49 PM
I have some problems converting units in CAS.
Here the display
1 as I introduce the command
2 after having pressed Enter
As you see after the Enter there is some backspace more and it ends with an error.
In home all works fine.
The nifty trick with the Sto button does't seem to work in CAS
Where is the problem?
Reto
Here the display
Reto
02-03-2015, 10:24 PM
try
3_cm►_m
worked for me here using the emulator.[/code]
3_cm►_m
02-03-2015, 10:48 PM
In home it works fine
In CAS it works but not properly.
The answer should be 0.03_m, but it gives _([0.03 _m]).
Why all the parenthesis?
02-03-2015, 11:09 PM
(02-03-2015 10:48 PM)retoa Wrote: [ -> ]In home it works fine
Interesting. I still don't know why we should use 'in' in Home and 'inch' in CAS.
02-03-2015, 11:17 PM
Basically, the CAS has "in" as a reserved word.
02-03-2015, 11:45 PM
I gave up trying to do unit conversions in the prime a while ago. The number of keystrokes and convoluted forms required to enter them are enough to make me want to poke my eyes in.
My prime sits atop my 50g and for any unit conversions required I move to the 50g. IMHO the way the 50g handles units is just about as perfect as it can get in a calculator. If I could magically change one thing in the Prime it would be to make units work like they do in the 50g.
02-03-2015, 11:54 PM
(02-03-2015 11:45 PM)ndzied1 Wrote: [ -> ]I gave up trying to do unit conversions in the prime a while ago. The number of keystrokes and convoluted forms required to enter them are enough to make me want to poke my eyes in.Apart from the extra parenthesis, I would say the number of keystrokes is the about the same. Using the 50g one also needs to nagivate thru menus and stuff. On the Prime I only have to key in the numbers, underline, unit, sto, underline unit and hit ENTER.
It~s Worth mentioning that the extra parenthesis won't affect you calculations.
02-04-2015, 12:34 AM
Textbook Display mode (Home Settings, page 2) and CAS don't always play well together. I usually leave it turned off.
02-04-2015, 01:45 AM
(02-03-2015 11:54 PM)Offroad Wrote: [ -> ](02-03-2015 11:45 PM)ndzied1 Wrote: [ -> ]I gave up trying to do unit conversions in the prime a while ago. The number of keystrokes and convoluted forms required to enter them are enough to make me want to poke my eyes in.Apart from the extra parenthesis, I would say the number of keystrokes is the about the same. Using the 50g one also needs to nagivate thru menus and stuff. On the Prime I only have to key in the numbers, underline, unit, sto, underline unit and hit ENTER.
I often find myself jumping back and forth multiple times between two units for instance gallons and liters. Once the menu is up I can assure you that going back and forth between units is much much easier on the 50g at least for me.
02-04-2015, 07:15 AM
(02-04-2015 12:34 AM)Joe Horn Wrote: [ -> ](02-03-2015 10:48 PM)retoa Wrote: [ -> ]In home it works fine
I changed to Algebraic Display mode but still have the same error when I use the convert command from the units menu and all the parenthesis when I use the sto button (in CAS).
I find the way you can convert units with the Prime in home with the sto button is very good and fast. And with the touchscreen choosing a unit it very easy, better then on the 50g. What I find very useful is the ability of the Prime to automatically simplify the units, like kg*m/s^2 to N.
02-04-2015, 06:56 PM
My real world example.
Convert 50 liters to galUS then convert 75 liters to galUS
50g required steps (12):
Prime required steps (24):
And the more conversions I have to do, the worse the Prime is because I always have to keep bringing back the unit menu and hitting Enter. :-(
- R-Shift
- Units
- Vol (F4)
- NXT
- 50
- l (F1)
- L-Shift
- gal (F4)
- 75
- l (F1)
- L-Shift
- gal (F4)
- 50
- Shift
- Units
- Volume (4)
- l (touch)
- Sto> (touch)
- Shift
- Units
- Volume (4)
- swipe up
- galUS (touch)
- Enter
- 75
- Shift
- Units
- Volume (4)
- l (touch)
- Sto> (touch)
- Shift
- Units
- Volume (4)
- swipe up
- galUS (touch)
- Enter
02-04-2015, 07:31 PM
Make a customized key that brings up a full choose-menu of all the units (you can even do nested choose menus by applying choose() in sequence) and outputs the proper units. Once done, you probably could do all your conversions in a few keypresses and touch-screen taps. Bind the key to the underscore symbol and then every time you type _ it should allow you to quickly pick the units. Your program can even keep track of the most recent menus, too.
That said, I do think the lack of menus from the HP48 through HP50 calcs is indeed a nuisance.
Here's an example (just modify it to add more categories and units):
Only 10 keystrokes/screentouches to convert from 1 meter to inches (or 12 if you count setting up user mode)
lastunit:={0,0};
KEY KS_Space()
local list1:={"Length", "Volume"};
local list2:={{"m","cm","in"},{"m^3","cm^3","in^3"}};
local c1,c2;
if lastunit(1) OR lastunit(2) then
c1:=lastunit(1); c2:=lastunit(2);
choose(c2,list1(c1),list2(c1));
else
c1:=0; c2:=0;
end;
if c2==0 then
repeat
choose(c1,"Units",list1);
if c1 then
end;
until c1==0 OR c2;
lastunit:={c1,c2};
end;
if c2 then return("_"+list2(c1,c2)); else return(""); end;
Pages: 1 2
