01-22-2015, 11:16 AM
01-22-2015, 11:53 AM
While in the conn kit, right click on the emulator's name. You can "Clone from here" to your calc. You could also back up the emu, and restore to the calc.
01-22-2015, 12:02 PM
Thank you DrD. It works :-)
Is there a way via Shift+Mem > Clone/Send?
01-23-2015, 12:52 PM
(01-22-2015 12:02 PM)jango Wrote: [ -> ]Is there a way via Shift+Mem > Clone/Send?
In the emulator's menu, mouse click on Calculator / Connect To, then select your calculator. Do the clone/send options then work? (It might depend on which version you're running).
01-25-2015, 07:01 PM
I had started another thread titled "How can I backup a user variable?" which fits with this one. I experimented some more, and it appears only user variables that are created using the EXPORT function are transferred. It also appears that when that variable is transferred, the value in it is not transferred with it. If the user variable was created from the home screen, at least I have not been able to transfer the variable. When viewing the variable in the memory manager, the variable created with EXPORT can be reset but not deleted. The user variable created from the home screen can be deleted in the memory manager. Functions appear to get transferred.
rcf
rcf
