01-22-2015, 10:54 AM
Non Volatile Write Stack to Memory for the HP35s
Greetings,
The following codes will read|write|exchange the current classic four level stack x,y,z,t with indirect memory 99, 98, 97, 96 (changeable) on the HP35s using available indirect memory addresses (built in) and the indirection registers (i) and (j).
This program utility may be used interactively to save|recall|exchange the stack in a non volatile way during normal calculations using parameters which may be easily changed, or the routines of the interactive program may also be called from other programs under automated control to save and restore the stack environment also in a non volatile way.
Have you ever wanted to save the stack environment momentarily (without a lot of manual exchanges or having to write down intermediate steps, or have you ever wished the four level stack could be expanded a bit without losing stuff out the TOP>?
Read on.
These codes assume some setup, and an understanding of indirect memory registers and indirect memory addressing on the HP35s. The user's guide which comes with the unit on CD covers this topic well.
I reserve 100 (0-99) indirect memory addresses which I may access with the (i) and (j) registers by placing a non zero value at indirect memory location 100. This takes up 37x101 bytes from the available 30192 bytes of on-board program storage, so that when placing -1 in memory location 100 the program storage byte counter (assuming no programs) will read 30192-(37x101). By default these codes read|write|exchange the stack x,y,z,t to memory locations 99,98,97,96 with the operator option at run time to not only select read|write|exchange but also to set the memory location. The assumption for this example code is a reserve of 101 memory locations.
On to the codes:
Usage:
Make sure that you have memories reserved for indirect addressing. This case assumes 101 reserved (but you can alter that) by placing a non zero value in indirect memory 100 like this:
100
STO J
-1
STO (J)
It is best to do this before you store any programs, but not essential.
To run the routines interactively use [XEQ] [T] [ENTER]
The default parameter -1 will be swapped from F into x stack position.
Select -1 leave default to EXCHANGE the stack with memory
Select 1 [+/-] to WRITE stack non volatile out to memory
Select 0 [CLx] to READ memory into stack
BE CAREFUL to not do anything that will cause STACK LIFT... to change to one use [+/-]
to change to 0 use the back arrow clear! If you activate stack lift you will lose the t TOP !
Press [R/S]
The default memory address counter will be 99.095 , which may be changed :
Make sure the counter represents a count down of 4. ie. 89.085 again, change it only
using back arrow clear so as to NOT activate stack lift !
Press [R/S]
That's all there is to it. If you want to use these same routines from within other programs to save or restore the environment in a nonvolatile way have your program call the appropriate ENTRY POINT for the routine you need. Again, make sure you have reserved the appropriate indirect memory addresses FIRST.
Greetings,
Read on.
On to the codes:
T001 LBL T
T002 x<> F
T003 CLx
T004 -1 (mode: -1 exchange default, 0 read, 1 write
T005 STOP (give the operator a chance to select the mode
T006 x<> F (save mode F=mode flag
T007 x<> J
T008 CLx
T009 99.095 (default counts 4 down from 99 to 95
T010 STOP (allow operator to change it ie. 89.085
T011 x<> J (save memory location (J) indirection counter
T012 x<> F (get mode flag -1 exchange, 0 read, 1 write
T013 x!=0? (DO on x not equal to zero
T014 GTO T022 (T022: branch around READ routine
T015 x<> F
T016 CLx (ENTRY POINT for READ routine
T017 RCL (J) ( start reading values from memory into the stack
T018 R| ( roll stack down arrow
T019 DSE J ( decrement counter | move to next memory
T020 GTO T016 ( loop back until all four values are read into stack
T021 RTN ( end of READ routine
T022 x>0? (continue branch from T014
T023 GTO T030 (T030: branch around EXCHANGE routine
T024 x<> F
T025 x<> (J) (ENTRY POINT for EXCHANGE routine
T026 R| ( roll stack down arrow
T027 DSE J ( decrement counter | move to next memory
T028 GTO T025 ( loop back until all four values are exchanged
T029 RTN ( end of EXCHANGE routine
T030 x<> F
T031 STO (J) (ENTRY POINT for WRITE routine
T032 R| ( roll stack down arrow
T033 DSE J ( decrement counter | move to next memory
T034 GTO T031 ( loop back until all four values are written
T035 RTN ( end of WRITE routine
100
STO J
-1
STO (J)
Press [R/S]
Press [R/S]
