01-09-2015, 05:51 PM
01-09-2015, 06:04 PM
Almost always - yes!
You can find most calculations/results in the application variables. For an example, VARS->[APP]->Stat1Var->Results->MedVal. That is the best way if you are going to use it many times or for futher calculations.
Should there be a result that isn't there in the app vars, or if it will be easier, you can always copy/paste. With the result you like selected, press SHIFT-VIEW (COPY) and then paste as desired.
If you can't find a result, please let me know because we tried hard to make sure everything was available outside.
