01-08-2015, 04:27 PM
Setting calculator's auto shutoff, by Wolfgang
Since FW 6940 there is the system variable TOff setting auto shutoff.
For further information please take a look at prime's help.
Attachment: Program setting the auto shutoff.
My special comment to Fw 6975: Wonderful!
Thx to the development team.
Wolfgang
Slider-addon by Thomas.
- graphic display of value 'Toff'
- change 'Toff' by clicking in slider
Wolfgang
#pragma mode( separator(.,;) integer(h32) )
SLIDER_INIT();
SLIDER_DRAW();
EXPORT TOFF()
// Firmware 6975
// integer systems settings are not recommended
// Number Format: Standard
// Setting the auto shutoff system-variable TOff
// limits are set between 1 minute and 60 minutes
// Softmenu with 5 soft buttons
// selectable increment and decrement steps
// steps of 1, 2, 5, 0.5 minutes
// WMWK 2015-01-05 Versin 0.97
// wolfgang.kuehn@vodafone.de
// add-on: slider (version 0.01); Thomas; 150108
LOCAL m,m1,mx,my,TF, TMul;
LOCAL TF0, xt;
RECT();
//TF = readout catual TOff in minutes
TF:=(B→R(TOff)/60000);
TEXTOUT_P("Setting Calculator's auto shutoff V 0.97",26,1,3);
TEXTOUT_P("TOFF = ",26,50,2);
// actual TOff
// actual TOff in minutes
TEXTOUT_P(B→R(TOff)/60000,65,50,2);
TEXTOUT_P("min", 95,50,2);
//actual TOff hex
TEXTOUT_P(R→B(TF*60000,32,4)+" ",139,50,2,#000000,100,#FFFFFF);
//actual TOff decimal
TEXTOUT_P(R→B(TF*60000,32,3)+" ",229,50,2,#000000,100,#FFFFFF);
SLIDER_INIT();
xt:=SLIDER_DRAW(TF, TF);
// Softmenu 5 buttons
DRAWMENU("TOff +","TOff -","SET","TOff *","BYE");
//Multiplier incr / decr
TMul:=1;
//outer loop
While Z <= 9999 DO
WHILE MOUSE(1)>=0 DO END;
//inner loop
REPEAT
m:=MOUSE;
m1:=m(1);
UNTIL SIZE(m1)>0;
mx:=m1(1);
my:=m1(2);
// query softbuttons
IF my>=220 AND my<=239 THEN
// menu button 1
IF mx>=0 AND mx<=51 THEN
TF0:=TF;
TF:=TF+1*TMul;
IF TF>60 THEN TF:=60; END;
xt:=SLIDER_DRAW(TF, TF0);
TEXTOUT_P(TF+" ",65,50,2,#000000,30,#FFFFFF);
TEXTOUT_P(R→B(TF*60000,32,4)+" ",139,50,2,#000000,140,#FFFFFF);
// menu button 2
IF mx>=53 AND mx<=104 THEN
TF0:=TF;
TF:=TF-1*TMul;
IF TF < 1 THEN TF:=1; END;
// menu button 3
IF mx>=106 AND mx<=157 THEN
TOff:=R→B(TF*60000);
TEXTOUT_P("TOff set",112,205,1,#000000,50,#FFFFFF);
// menu button 4
IF mx>=159 AND mx<=210 THEN
CASE
IF TMul=1 THEN TMul:=2;END;
IF TMul=2 THEN TMul:=5;END;
IF TMul=5 THEN TMul:=0.5;END;
IF TMul=0.5 THEN TMul:=1;END;
TEXTOUT_P("TMul = "+TMul+" ", 164,205,1,#000000,50,#FFFFFF);
// menu button 5
IF mx>=212 AND mx<=263 THEN
RETURN;
// inner loop
// outer loop
// slider?
IF my>=101 AND my<=119 THEN
IF mx>30 AND mx<300 THEN
TF0:=TF;
TF:=1+IP((59.5*((mx-30)/270)));
END; // slider
SLIDER_INIT()
// box for slider, min, max
// t odo: (global?) constants:
// position (x,y), size (x,y), value(s)(min, max)
RECT_P(G0, 28,100, 302,120, #0, #FFFFFF);
TEXTOUT_P("1" , 20,105,2);
TEXTOUT_P("60",304,105,2);
// (re)draws slider.
// todo: constans! (see SLIDER_INIT)
// conversion of value(e) <--> position
LOCAL xTF, xTF0, off, br;
off:=2;
br:=3; // width of slider
// x pos slider
xTF := IP( 32 + (((TF -0.99)/59) *266));
xTF0 := IP( 32 + (((TF0-0.99)/59) *266));
// redraw slider
RECT_P(G0, (xTF0-3),101, (xTF0+3),119, #FFFFFF, #FFFFFF);
RECT_P(G0, (xTF -3),101, (xTF +3),119, RGB(255,0,0), RGB(255,0,0));
// value
off:=2;
IF TF>9 THEN off:=5; END;
RECT_P(G0, xTF0-5,123, xTF0+15,133, #FFFFFF, #FFFFFF);
TEXTOUT_P(TF+" ",xTF-off,125,1);
RETURN xTF;
