01-03-2015, 01:18 PM
Hello all,
I've been struggling with vector editing in the home view for some time now. I've tried to delete elements from the vector, but had no luck using the delete key (as could be considered the intuitive way). Then, after careful re-reading of the manual and some forums, I've found that you can switch to matrix by using the '[]' key (shift 5) and back again. After swapping to matrix, you CAN delete the col you want, by going to the plus minus sign and pressing del, and then go back to vector, but I find it quite inefficient.
Could it be possible to make it a bit easier?, just by using the delete key, or adding a menu to "edit" the vector/matrix (in the editor it's easier to delete an element).
Thanks for your time,
Pedro.
Pedro.
