I integrated Han's latest changes into my latest code and did some measurement on my HP Prime. Function used for testing was (X^2-1)*(X-2-i)^2/(X^2+2+2*i), and plot setting was X= -4 to 4, Y= -3 to 3, Box=4, Resolution=0.01, Coloring: Red-Yellow, RE/IM Contour enabled.
[EDITED with new test result] I tested couple of times more after I initially uploaded test result, and the times were not coming in consistently.. I tested some more and found out:
1. There seems to be some performance degradation after running calculator some time.. maybe there is a memory leak or something like that.. so I did reset (symb+on key) for each test run to counter this.
2. if you leave the calculator without touching key or screen while doing the plot, it seems to take longer time.. probably there is some power saving routine that comes in when screen/key is not pressed for some period. I countered by periodically touching the screen to prevent power saving.
With 1 and 2 additional conditions above, I ran each case twice and I am now getting consistent results. Times below:
1. new code (inc. Han's improvements), single sweep with PIXELON_P(box=0): 1st run=4:58, 2nd run=5:01
2. new code, PIXELON_P for last sweep: 1st=5:02, 2nd=5:00
3. new code, RECT_P for all sweep: 1st=5:05, 2nd=5:05
4. old code, PIXELON_P for last sweep: 1st=5:19, 2nd=5:18
So, Han's code change does show good improvement, and PIXELON_P change also shows improvement, although it's a very minimal improvement.
I am attaching the new code below, so if anyone is interested feel free to test and let us know the result (after all, our focus should be the best performance on the actual calculator).
// SetHSV() and GetColor() based on a
// c++ program from :
// http://commons.wikimedia.org/wiki/File:Color_complex_plot.jpg
// by Claudio Rocchini
// http://en.wikipedia.org/wiki/Domain_coloring
//Global variables
initComp:=0;
r; //r is size of initial square which is 2^r by 2^r pixels
c;
coloring;
REGridOn;
IMGridOn;
em1:=1/(e-1);
SetHSV(h,s,v);
GetColor(v);
EvalF();
gComp_setdefault();
gComp_getsettings();
PlotSetup()
begin
if initComp==0 then
gComp_setdefault();
end;
end;
gComp_setdefault()
Xmin:=-4; Xmax:=4;
Ymin:=-3; Ymax:=3;
r:=4;
c:=.01;
coloring:=1;
initComp:=1;
REGridOn:=1;
IMGridOn:=1;
end;
view "Set Plot Options",gComp_getsettings()
begin
local j;
if initComp==0 then
gComp_setdefault();
end;
local xmintemp:=Xmin,xmaxtemp:=Xmax;
local ymintemp:=Ymin,ymaxtemp:=Ymax;
local coloringtemp:=coloring;
local rtemp:=r,ctemp:=c,REGridOntemp:=REGridOn,IMGridOntemp:=IMGridOn;
if input(
{xmintemp,[0],{15,30,0}},
{xmaxtemp,[0],{65,30,0}},
{ymintemp,[0],{15,30,1}},
{ymaxtemp,[0],{65,30,1}},
{rtemp,[0],{15,20,2}},
{ctemp,[0],{65,30,2}},
{coloringtemp,{"Red-Yellow Domain Coloring","HSV Domain Coloring", "Logarithmic"},{20,30,3}},
{REGridOntemp,0,{90,10,4}},
{IMGridOntemp,0,{90,10,5}}
"Plot Setup",
"Xmin=", "Xmax=",
"Ymin=", "Ymax=",
"Box=", "Resolution=",
"Coloring",
"RE Contour Grid",
"IM Contour Grid"
"Enter minimum horizontal value",
"Enter maximum horizontal value",
"Enter minimum vertical value",
"Enter maximum vertical value",
"Initial pixel square width. Enter 0 for one pass",
"Resolution for contour grid & magnitude mask",
"Select coloring scheme",
"Draw Real Contour Grids",
"Draw Imaginary Contour Grids"
then
textout_p("Applying plot options...",G0,1,1,1,0,320,#FFFFFFh);
if xmintemp>=xmaxtemp then
msgbox("Warning: Invalid Xmin/Xmax! Setting Xmax:=Xmin+1");
xmaxtemp:=xmintemp+1;
end;
if ymintemp>=ymaxtemp then
msgbox("Warning: Invalid Ymin/Ymax! Setting Ymax:=Ymin+1");
ymaxtemp:=ymintemp+1;
end;
if rtemp<0 then
msgbox("Warning: Box size must be >= 0; reset to 4");
rtemp:=4;
end;
if (xmintemp<>Xmin) OR (xmaxtemp<>Xmax) OR
(ymintemp<>Ymin) OR (ymaxtemp<>Ymax)
then
Xmax:=xmaxtemp; Xmin:=xmintemp;
Ymax:=ymaxtemp; Ymin:=ymintemp;
end;
if rtemp<>r then
r:=rtemp;
end;
if ctemp<>c then
c:=ctemp;
end;
if coloringtemp<>coloring then
coloring:=coloringtemp;
end;
if REGridOntemp<>REGridOn then
REGridOn:=REGridOntemp;
end;
if IMGridOntemp<>IMGridOn then
IMGridOn:=IMGridOntemp;
end;
end;
end;
EXPORT Plot()
local x1,x2,y1,y2,co;
local dx:=(Xmax-Xmin)/320;
local dy:=(Ymax-Ymin)/240;
local z1;
local a,b,b1,d,k,x,y;
d:=2^r;
IF r>0 THEN
FOR x FROM 0 TO 320-d STEP d DO
FOR y FROM 0 TO 240-d STEP d DO
z1:=Xmin+x*dx+i*(Ymin+(240-d-y)*dy);
co:=EvalF(z1);
RECT_P(G0,x,y,x+d-1,y+d-1,co);
FOR k FROM 1 TO r-1 DO
d:=2^(r-k);
FOR x FROM 0 TO 160/d-1 DO
FOR y FROM 0 TO 120/d-1 DO
a:=x*2*d; b:=y*2*d; b1:=(120/d-1-y)*2*d+d;
z1:=Xmin+a*dx+i*(Ymin+b1*dy);
co:=EvalF(z1);
RECT_P(G0,a,b,a+d-1,b+d-1,co);
z1:=z1+d*dx;
co:=EvalF(z1);
RECT_P(G0,a+d,b,a+2*d-1,b+d-1,co);
z1:=z1+i*d*dy;
co:=EvalF(z1);
RECT_P(G0,a+d,b-d,a+2*d-1,b-1,co);
d:=1;
co:=EvalF(z1);
// RECT_P(G0,a,b,a+d-1,b+d-1,co);
PIXON_P(G0,a,b,co);
z1:=z1+d*dx;
co:=EvalF(z1);
// RECT_P(G0,a+d,b,a+2*d-1,b+d-1,co);
PIXON_P(G0,a+d,b,co);
z1:=z1+i*d*dy;
co:=EvalF(z1);
// RECT_P(G0,a+d,b-d,a+2*d-1,b-1,co);
PIXON_P(G0,a+d,b-d,co);
ELSE
co:=EvalF(z1);
PIXON_P(G0,x,y,co);
WHILE 1 DO
FREEZE;
// WAIT(-1);
EvalF(z)
IF RE(z) THEN
RETURN(GetColor(F1(z)));
ELSE
RETURN(GetColor(F1(z+.001)));
SetHSV(h, s, v)
LOCAL r, g, b;
LOCAL z, f, p, q, t, i;
IF(s==0) THEN
r:=v;
g:=v;
b:=v;
ELSE
IF(h==1) THEN h := 0; END;
z := h*6;
i := IP(z);
f := FP(z);
p := v*(1-s);
q := v*(1-s*f);
t := v*(1-s*(1-f));
CASE
IF i==0 THEN r:=v; g:=t; b:=p; END;
IF i==1 THEN r:=q; g:=v; b:=p; END;
IF i==2 THEN r:=p; g:=v; b:=t; END;
IF i==3 THEN r:=p; g:=q; b:=v; END;
IF i==4 THEN r:=t; g:=p; b:=v; END;
IF i==5 THEN r:=v; g:=p; b:=q; END;
r :=MIN(255,IP(256*r));
g :=MIN(255,IP(256*g));
b :=MIN(255,IP(256*b));
RETURN RGB(r,g,b);
GetColor(v)
LOCAL a:=0;
LOCAL m,k,sat,val;
IF v≠0 THEN a:=ARG(v); END;
a:=a MOD (2*π);
a := a/(2*π);
// RE Contour
IF REGridOn then
m := ABS(RE(v));
k:=m/c;
IF m>c then
k:=(m/(c*e^FLOOR(LN(m)-LN(c)))-1)*em1;
sat:=2*k;
IF k>=0.5 THEN sat:=2-sat; END;
val := 1-0.4*sat^3;
sat := 1 - (1-sat)^3; sat := 0.4 + sat*0.6;
IF (val > 0.9999) OR (sat >0.9999) THEN
IF coloring==1 THEN a:=a/6; ELSE IF coloring==3 THEN return RGB(200,200,200); END; END;
return SetHSV(a,sat,val);
//IM Contour
IF IMGridOn then
m := ABS(IM(v));
k:=m/c;
IF m>c then
sat:=2*k;
val := 1-0.4*sat^3;
IF coloring==1 THEN a:=a/6; ELSE IF coloring==3 THEN return RGB(255,255,255); END; END;
//Domain Coloring
IF coloring==3 THEN
return RGB(MIN(255,LN(1+ABS(IM(v)))*128),MIN(255,LN(1+ABS(RE(v)))*128),MIN(255,MAX(0,(LN(1+ABS(v))-2)*128)));
m := ABS(v);
k:=m/c;
IF m>c then
sat:=2*k;
val := 1-0.4*sat^3;
IF coloring==1 THEN a:=a/6; END;
