12-29-2013, 07:56 PM
I leave the link to a small program I wrote to calculate the current limiting resistor for a given number of LED diodes in series.
http://www.ucontrol.com.ar/forosmf/tutor.../#msg82727
It's in Spanish, but if you think you need someone can translate it to English language.
I hope you find it useful.
![[Image: ?action=dlattach;attach=16081]](http://www.ucontrol.com.ar/forosmf/tutoriales-guias-y-cursos-en-ucontrol/calculo-de-resistencia-limitadora-para-leds-en-serie-con-hp-prime/?action=dlattach;attach=16081)
![[Image: ?action=dlattach;attach=16083]](http://www.ucontrol.com.ar/forosmf/tutoriales-guias-y-cursos-en-ucontrol/calculo-de-resistencia-limitadora-para-leds-en-serie-con-hp-prime/?action=dlattach;attach=16083)
![[Image: ?action=dlattach;attach=16079]](http://www.ucontrol.com.ar/forosmf/tutoriales-guias-y-cursos-en-ucontrol/calculo-de-resistencia-limitadora-para-leds-en-serie-con-hp-prime/?action=dlattach;attach=16079)
Greetings.
EXPORT resistencia_led()
//Declaro variables:
local RL, VLED, NLED, ILED,VCC,POT;
local lista1, lista2;
lista1 := {"Vcc:", "VLED:", "ILED:","nLED:"};
lista2 := {"Tensión de la fuente (V)","Tensión del LED (V)","Corriente del LED (A)","Número de LEDs conectados en serie"};
INPUT ({VCC,VLED, ILED,NLED},"Cálculo resistencia limitadora (Ohms)",lista1, lista2);
RL := (VCC-VLED*NLED)/ILED;
IF RL<0 THEN
MSGBOX("El número de LEDs excede la tensión de la fuente.");
ELSE
POT := (ILED^2)*RL;
RL := ROUND(RL,0);
POT := ROUND(POT,1);
print (RL);
print (POT);
MSGBOX("La resistencia limitadora debe ser de "+ RL +" Ohm(s) y al menos " + POT+ " Watt(s).");
Greetings.
