12-29-2014, 08:53 AM
Started the Emulator.
Cloned physical calculator to Emulator.
Now they are the same right???
Not so fast Buckaroo.
None of the programs that call OTHER programs now work.
(everything was working fine on the physical calculator )
If you open the programs that call OTHER programs and do a "CHECK",
the OTHER programs that are called show as having a "problem".
If you then open the OTHER called programs and "CHECK" everything is reported as OK. i.e. there was no problem in the first place.
Now it works in the program that called it.
Apparently, you have to go and "re-compile" all your programs that may be called by others?
Holy Shit, are you kidding?
So far i have about 30-40 of these.
I wonder if this is true when you clone one physical calculator to another physical calculator ???
What about RESTORING one physical calculator to another physical calculator ???
How would you ever distribute mildly sophisticated programs??
