12-28-2014, 09:09 PM
12-28-2014, 10:54 PM
(12-28-2014 09:09 PM)mpowell@rogershsa.com Wrote: [ -> ]Hi, is there a way to make the lines thicker when graphing with the HP Prime?
Not currently. In the Advanced Graphing app, you could replace an equation with an inequality (e.g., ABS(Y-SIN(X))<.1 instead of Y-SIN(X)=0), but the thickness would depend on how much you've zoomed in (and isn't uniform — it's not the Minkowski sum of a curve with a disc, but instead is the union of a bunch of level sets).
12-29-2014, 12:23 AM
A rather cheesy way to do this is to "scribble" another curve on top.
If F1(X) has your function
F2(X): F1(X)+sin(100X)
Will darken the plot up a little.
Anyhow, I agree with your request and also hope they add log scales as an option.
12-29-2014, 04:57 AM
In addition to thicker lines and log axes, I'd like to see larger point symbols on scatter plots.
12-29-2014, 04:11 PM
Log axes option (base 10) will be nice.
Not so sure about thicker lines and bigger symbols - - things will get too crowded very quickly. The current line style / resolution is fine with me.
