Full Version: Connectivy Kit
Hello
The logicel Connectivy Kit refuses to install on my Vista PC .
I get an error 0x800b010a .
Is it compatible ?
Sorry to hear of your troubles.
First, I'd try installing under Administrative privileges. Right click the installing program and choose Run As Administrator.
Otherwise, Microsoft has quite a bit of information on this error code on their MSDN site:
http://msdn.microsoft.com/en-us/library/...s.85).aspx
Looks like a complicated problem with trusted install certificates. Good luck.
Bill
(12-25-2014 12:38 PM)Tyann Wrote: [ -> ]Hello
Is it compatible ?
Yes, it should be compatible. This is the first "install error" I've heard of yet. Were you able to figure it out?
There seems to be a certificate problem !
