12-22-2014, 10:18 AM
I have a problem with the rev 6975. It worked in the beginning but don't works now.
The problem is :
-The virtual calulator works fine
-The connectivity kit seems to work fine
but when I tries to push (for example it freezes in others cases) a program from the CK to the virtual calculator then the virtual calculator freezes I can push the virtual keybord but nothing happens. The only thing is to reset the virtual calc, with the same problem after...
I tried to desinstall/reinstall all but always the same problem. Is there some directory or keys register entries to delete manually ?
The problem is :
