12-19-2014, 05:13 PM
this program is borrowed from the german HP-Prime forum.
It was written because the builtin terminal has some drawbacks (which were introduced in some recent firmware update) -- mainly very size-limited line buffer and not displaying the most recent PRINTed line.
Beware: This program does not break long lines as the builtin terminal would do, and G9 is used as drawing buffer.
Program "TERM":
Usage:
Replace "PRINT()" by "TERM.CLEAR()", "PRINT(data)" by "TERM.OUT(data)", and call "TERM.SHOW()" to view the buffer. (Omit the prefix "TERM." if "CLEAR", "OUT", "SHOW" don't collide with other function names).
If "TERM.LiveView" is set to 0 the program won't display anything until "SHOW()"ed.
Scroll to top/bottom by cursoring left/right, or otherwise 1/3-page up/down.
Keys [1],...,[7],[+],[-] will change font size.
Test program "TERMTEST" for comparing builtin terminal vs. "TERM":
Any improvements are very welcome. Ideas: handle line breaks, long lines, tabulators, highlight numbers, better type handling in general etc.
This program might become obsolete eventually, when the Prime's builtin terminal is upgraded.
Greetings
[EDIT] Thread renamed to not disrupt the sequence of "HP Prime: ..." articles by E. W. Shore when alphabetically sorted.
Program "TERM":
EXPORT LiveView:=1; // Visible while outputting?
BackColor:=RGB(0,0,0);
TextColor:=RGB(0,255,0);
BarBColor:=RGB(0,128,0);
BarFColor:=RGB(64,255,64);
Capacity:=9999; // = max list size
FontSize:=2;
Buffer:={};
LastTouchY,Top;
LineHeight()
BEGIN 2*FontSize+10; END;
TotalHeight()
BEGIN SIZE(Buffer)*LineHeight; END;
MaxTop()
BEGIN MAX(TotalHeight-240,0); END;
Redraw(top)
// Draw buffered lines
LOCAL h:=LineHeight;
LOCAL n:=SIZE(Buffer),
k:=IP(top/h),
y:=-(top MOD h);
DIMGROB_P(G9,320,240,BackColor);
WHILE k<n AND y<240 DO
TEXTOUT_P(Buffer(k:=k+1),G9,0,y,
FontSize,TextColor);
y:=y+h;
// Draw scrollbar
LOCAL t:=TotalHeight;
IF t≥240 THEN
y:=240*top/t;
RECT_P(G9,318,0,319,239,BarBColor);
RECT_P(G9,318,y,319,y+240²/t,BarFColor);
// Show
BLIT(G9);
Top:=top;
MoveTo(top)
top:=MAX(MIN(top,MaxTop),0);
IF top≠Top THEN Redraw(top); END;
Resize(fontSize)
fontSize:=MAX(MIN(fontSize,7),1);
IF fontSize≠FontSize THEN
FontSize:=fontSize;
Redraw(MIN(Top,MaxTop));
HandleTouch(touch)
IF touch(1)≤#1 THEN
LOCAL y:=B→R(touch(3));
CASE
IF touch(2)≥#300d
THEN MoveTo(y/240*TotalHeight); END;
IF touch(1)=#1
THEN MoveTo(Top+LastTouchY-y); END;
LastTouchY:=y;
HandleKey(code)
CASE
IF code=7 THEN MoveTo(0); END;
IF code=8 THEN MoveTo(MaxTop); END;
IF code=2 THEN MoveTo(Top-80); END;
IF code=12 THEN MoveTo(Top+80); END;
IF code=42 THEN Resize(1); END;
IF code=43 THEN Resize(2); END;
IF code=44 THEN Resize(3); END;
IF code=37 THEN Resize(4); END;
IF code=38 THEN Resize(5); END;
IF code=39 THEN Resize(6); END;
IF code=32 THEN Resize(7); END;
IF code=45 THEN Resize(FontSize-1); END;
IF code=50 THEN Resize(FontSize+1); END;
// Clear the terminal buffer.
EXPORT CLEAR()
Buffer:={};
IF LiveView THEN Redraw(0); END;
// Add a single line or a list of lines to terminal buffer.
EXPORT OUT(data)
LOCAL s:=SIZE(Buffer)+
IFTE(TYPE(data)=6,SIZE(data),1);
IF s>Capacity THEN
Buffer:=SUB(Buffer,s-Capacity+1,Capacity);
Buffer:=CONCAT(Buffer,data);
IF LiveView THEN Redraw(MaxTop); END;
// Show the terminal buffer contents.
EXPORT SHOW()
LOCAL inp;
REPEAT
IF TYPE(inp:=WAIT(-1))=6
THEN HandleTouch(inp); inp:=-1;
ELSE HandleKey(inp); END;
UNTIL inp=30 OR inp=4; // leave on [Enter] or [Esc]
Usage:
EXPORT TERMTEST1()
PRINT();
LOCAL n:=0,s;
REPEAT
s:=STRINGFROMID(n:=n+1);
PRINT(n+": "+s);
UNTIL s="LASTSTRING";
EXPORT TERMTEST2()
CLEAR();
LOCAL n:=0,s;
REPEAT
OUT(n+": "+s);
SHOW();
Greetings
