12-09-2014, 11:11 PM
"Change apparent integer into exact integer" don't work. - the check box after Integers settings on first page.
When checked, entering 2.0 returns 2. instead 2
(12-09-2014 11:11 PM)slawek39 Wrote: [ -> ]"Change apparent integer into exact integer" don't work. - the check box after Integers settings on first page.
(12-10-2014 12:04 AM)Han Wrote: [ -> ]Thank you for the valuable information.(12-09-2014 11:11 PM)slawek39 Wrote: [ -> ]"Change apparent integer into exact integer" don't work. - the check box after Integers settings on first page.
According to the help text:
"If checked, any real number equivalent to an integer in a non-CAS environment will be converted to an integer in the CAS. (Real numbers not equivalent to integers are treated as real numbers in CAS whether or not this option is selected."
1. Entering numbers with the fraction symbol (typically the decimal point ".") tells the CAS that the number being entered is specifically NOT an exact value. Thus, typing in 2.0 will not convert the value to 2 (without the fraction symbol). This is common in many CAS and is not limited to just the HP Prime.
2. The option only applies to data imported from non-CAS environments. I think this is referring to, as an example, values stored in the built-in global variables normally used in the Home view. That is, if you save 2.0 into the variable A, the CAS will interpret that as 2 and not 2.0. Even if you enter in A:=2.0, the CAS uses 2 instead because it's pulling the value of A from a non-CAS environment. Similar behavior can be seen when using data from various apps or when using values pulled from Home view (and the user has set Fixed 4 mode for numbers), etc.
That's how I understand it.
