k=0.0116_(1/cm)
l=600_cm
Upper expression differs from the bottom in that the square is applied to the total. You can tell from the offset 2. There should be parentheses.
Yes, it does need them for display. I wasn't able to fix that one unlike the e^t^2 thing due to being a more pervasive impact and we were too close to release.
I apologize if I am asking the same question in so many places but how did you get the 6940 firmware? I am trying to get it but can not locate it anywhere
(12-05-2014 02:56 AM)marcusnicolas1 Wrote: [ -> ]I apologize if I am asking the same question in so many places but how did you get the 6940 firmware? I am trying to get it but can not locate it anywhere
1. Use the connectivity kit and check for updates.
OR
2.
http://www.hpmuseum.org/forum/thread-2536.html
Thanks. WHen I try the link, it says this message FORBIDDEN: You don't have permission to access /pub/calculators/Prime/ on this server.
Then when I press update with the connectivity kit, it states there are no updates available. I am not sure what is going on.
(12-05-2014 03:43 AM)marcusnicolas1 Wrote: [ -> ]Thanks. WHen I try the link, it says this message FORBIDDEN: You don't have permission to access /pub/calculators/Prime/ on this server.
Yeah, it's supposed to be an FTP link but the forum apparently doesn't like them.
Here's an http shortlink :
http://goo.gl/dWbPAG
Edit : uh oh, looks like the 6940 version got pulled out of the FTP server ?
Here's a mirror for those who want it :
https://tiplanet.org/forum/archives_voir.php?id=118947
But beware, if it's not available officially anymore, there might be a reason ?
(12-05-2014 05:20 AM)Adriweb Wrote: [ -> ]But beware, if it's not available officially anymore, there might be a reason ?
A "square" of reason actually.
(12-05-2014 05:20 AM)Adriweb Wrote: [ -> ] (12-05-2014 03:43 AM)marcusnicolas1 Wrote: [ -> ]Thanks. WHen I try the link, it says this message FORBIDDEN: You don't have permission to access /pub/calculators/Prime/ on this server.
Here's an http shortlink : http://goo.gl/dWbPAG
Here's a mirror for those who want it : https://tiplanet.org/forum/archives_voir.php?id=118947
Got it, but how do I send it to the HP Prime to update it?
