(10-04-2015 09:54 AM)Hans Brueggemann Wrote: [ -> ]- 25 to go to make the next batch happen!
Hans
My sincere thanks go to Bob and Dave for their unbelievable enthusiasm and support!
One for me please, thus 24 to go.
Günter
two for me please, thus 22 to go.
Patrick
[/quote]
Hallo Hans!
As I PM you I'm seriously interested too - take me on your list
kind regards
Erwin
(05-16-2015 07:23 PM)Hans Brueggemann Wrote: [ -> ]it requires at least 30 or more seriously(!) interested pre-orders to economically justify another production run. so, there are no plans to do that until there are enough people banging at my door.
one more firmware spin is in planning to add a feature that i personally would really like to have on my FRAM71. however, i want to analyze the feasibility first before i disclose anything about that V600.
If it isn't too late to join the party, please put me down for one 1MB unit.
Thanks,
Chris
(01-22-2016 08:59 PM)chrisbennett Wrote: [ -> ]If it isn't too late to join the party, please put me down for one 1MB unit.
Thanks,
Chris
With the pre-orders in this thread plus the
official list, and not counting PM's, that makes 15 modules. We're halfway there!
I may be interested for one unit, but I would like to have updated information about functionality and cost. Please, if appropriate, send such info to:
a DOT rodriguez AT ieee DOT org
Thank you in advance.
(01-25-2016 10:40 PM)Andres Wrote: [ -> ]I may be interested for one unit ...
Hi Andres,
If you're even slightly interested, please add your name to the thread,
PRE-ORDER POLL: FRAM71B. Note that there is
no obligation to buy but by doing so you will help to trigger the next production run when the number of interested persons reaches 30.
See the above thread for info about new functionality and pricing.
Sh**, two identical ordering lists. Maybe Hans could give us an update of the batch order. This might let us know, how long we have to wait for this masterpiece?
Matthias
(01-26-2016 12:50 AM)HP-Collection Wrote: [ -> ]Sh**, two identical ordering lists. Maybe Hans could give us an update of the batch order.
No, the lists are not identical.
PRE-ORDER POLL: FRAM71B is the list. The folks putting their names down in this thread started to do so after HHC 2015, before Hans posted the Pre-Order Poll.
We're probably only about half-way there depending on if the criteria is 30 persons or 30 modules.
no worries, gents, i've an eye on both threads. would help if all requests go into the
PRE-ORDER POLL: FRAM71B, though.
hans
(05-08-2015 01:44 AM)Dave Frederickson Wrote: [ -> ] (05-08-2015 12:03 AM)Christoph Giesselink Wrote: [ -> ]I personally use a modified version of JFG's alifhdr to convert a DOS or UNIX style text file into a LIF1 text file with a 32byte LIF text file header ("alifhdr input_file LIF_file /T").
The resulting LIF_file then can be directly transferred with the ILDoslink device to a HP71 ("COPY :DOSLINK").
Thanks go to Sylvain and Bob for the ROM images. Special thanks to J-F Garnier for the Diag ROM image and many of the EPROM images.
Dave
Hallo,
I fiddle around to prepare my FRAM71B. I have a custom Eprom (64k) with a modified MathROM and the JPC LEX. I want to transfer the MathROM part on my Harddisk using PYILPER and the PILBOX and then back on the FRAM71B. I'm on a MAC so the solutions in this tread are not possible for me. I have the FRAM71B installed and started to config the first steps. So I could not find examples on the board for copying ROM to my hard disc I tried it with the document for ROMCOPY. The SHOWPORT gave me following result:
PHP Code:
0.05 16384 2
1 65536 2
0 4094 0
0.01 4094 0
0.02 4094 0
0.03 4094 0
5 32768 0
I prepared a new LIF-file on my hard disc and tried to transfer the image from the Eprom with
PHP Code:
ROMCOPY :PORT(1) TO FILE:HRDIVE1
It ends in an error. It looks like that I misunderstood the syntax in the ROMCOPY document. Are there any helpful hands out there?
The descriptions I found on the board are only in the reverse way, cause the ROMs available for download :-)
Thank you
Erwin
Hi Erwin,
Can't you simply copy the MATHROM file from the EPROM to FRAM71B?
ROMCOPY will copy a PORT (IRAM or ROM) to a ROM image file or a ROM image file to an IRAM.
Dave
(10-04-2016 08:36 PM)Dave Frederickson Wrote: [ -> ]Hi Erwin,
ROMCOPY will copy a PORT to a file or visa versa.
Dave
Hi Dave,
Yes when it is possible in such a way - but no idea how to do this. I only want the MATHROM part not the JPCROM from this EPROM. I would prepare the FRAM like Sylvain did it in his post (
http://www.hpmuseum.org/forum/thread-5068.html) and before copy my MATHROM. Can you give me a hint how to copy this EPROM part in the IRAM like you proposed?
Thanks Erwin
Hi Erwin,
Something like: COPY MATHROM:PORT(1) TO :MAIN
Depending on whether or not your MATHROM is protected you might get an error.
Dave
(10-04-2016 08:51 PM)Dave Frederickson Wrote: [ -> ]Hi Erwin,
Dave
Thank you Dave
that was too easy :-) test was successful
best regards
Erwin
