11-26-2014, 06:56 AM
11-26-2014, 02:52 PM
This is not possible at this time. I've put it down on the suggestion list though. I think we could probably make it so that if there was an image object in the place of the "lablel" text it would use that as the item to display.
11-26-2014, 07:36 PM
It would be a great tool to add this possibility in the INPUT command !
11-26-2014, 10:21 PM
adding images to the input would be nice to re-create an eq library a la hp48 style...
thanks
Giancarlo
thanks
Giancarlo
11-27-2014, 12:07 AM
(11-26-2014 02:52 PM)Tim Wessman Wrote: [ -> ]This is not possible at this time. I've put it down on the suggestion list though. I think we could probably make it so that if there was an image object in the place of the "lablel" text it would use that as the item to display.
A label/text only field would be nice too (i.e. to just place text on the screen that isn't attached to any particular input).
11-27-2014, 03:44 AM
A shame, it's amazing that with my HP 50 if does and with no current device.
![[Image: if_main_grob.png~original]](http://i70.photobucket.com/albums/i106/cyberespia/if_main_grob.png~original)
11-28-2014, 01:25 AM
(11-27-2014 03:44 AM)Mariox Wrote: [ -> ]A shame, it's amazing that with my HP 50 if does and with no current device.
You can do the same but handling everything
It is a lot of work, but at least it is possible since you can control all the display in the Prime.
