11-24-2014, 07:39 PM
Hill’s ciphering algorithm can be accomplished on the HP 42S using the following programmes.
To use:
1. Actuate programme HILL to set parameters.
2. ENCY encodes the alpha register, returning the coded message to the alpha register.
3. DECY decodes the alpha register, returning the clear message to the alpha register.
0. { 33-Byte Prgm }
1. LBL “R10”
2. RAN
3. SF 25
4. RCL “RMAX”
5. FC?C 25
6. 10
7. *
8. IP
9. RAN
10. 0.5
11. –
12. SIGN
13. *
14. END
Produces one random integer element of the ciphering matrices.
0. { 43-Byte Prgm }
1. LBL “LTRI”
2. ENTER
3. NEWMAT
4. EDIT
5. LBL 00
6. RCLIJ
7. X=Y?
8. GTO 01
9. XEQ “R10”
10. →
11. GTO 00
12. LBL 01
13. SIGN
14. STOEL
15. STOIJ
16. I+
17. FC? 76
18. GTO 00
19. CLX
20. EXITALL
21. END
Forms a lower triangular square matrix for integer input
Eg 3 LTRI returns a 3*3 LT matrix.
0. { 22-Byte Prgm }
1. LBL “MMOD”
2. EDIT
3. LBL 00
4. RCL ST Y
5. MOD
6. →
7. FC? 77
8. GTO 00
9. EXITALL
10. END
Makes the matrix in X-register modulo the integer in the Y-register
Eg 7 matrix MMOD returns the matrix modulo 7.
0. { 34-Byte Prgm }
1. LBL “A→M”
2. ALENG
3. RCL/ ST Y
4. ENTER
5. FP
6. X>0?
7. SIGN
8. +
9. X<>Y
10. NEWMAT
11. EDIT
12. LBL 00
13. R↓
14. ATOX
15. →
16. FC? 77
17. GTO 00
18. EXITALL
19. END
Converts the alpha-register contents to a matrix of integers of column dimension the X-reister
Eg 3 A→M returns a 3-coumn matrix.
0. { 95-Byte Prgm }
1. LBL “HILL”
2. INPUT “RMAX”
3. INPUT “SHIFT”
4. INPUT “CYMOD”
5. INPUT “MSIZE”
6. XEQ “LTRI”
7. ENTER
8. ENTER
9. TRANS
10. *
11. RCL “CYMOD”
12. X<>Y
13. XEQ “MMOD”
14. STO “INMAT”
15. R↓
16. X<>Y
17. FIX 00
18. INVRT
19. RND
20. ALL
21. ENTER
22. TRANS
23. X<>Y
24. *
25. XEQ “MMOD”
26. STO “OUTMAT”
27. END
Asks for the coding parameters.
Eg For capitals in to capitals out:
Alpha to alpha: SHIFT 65
CYMOD 26
For any character in to any character out:
All to all: SHIFT 0
CYMOD 256
0. { 85-Byte Prgm }
1. LBL “ENCY”
2. RCL “INMAT”
3. GTO 00
4. LBL “DECY”
5. RCL “OUTMAT”
6. LBL 00
7. ENTER
8. DIM?
9. X<>Y
10. R↓
11. XEQ “A→M”
12. X<>Y
13. *
14. RCL+ “SHIFT”
15. RCL “CYMOD”
16. X<>Y
17. XEQ “MMOD”
18. RCL+ “SHIFT”
19. LBL “M→A”
20. CLA
21. XTOA
22. AVIEW
23. END
ENCY encodes the alpha-register & DECY decodes the alpha-register.
To use:
0. { 33-Byte Prgm }
1. LBL “R10”
2. RAN
3. SF 25
4. RCL “RMAX”
5. FC?C 25
6. 10
7. *
8. IP
9. RAN
10. 0.5
11. –
12. SIGN
13. *
14. END
0. { 43-Byte Prgm }
1. LBL “LTRI”
2. ENTER
3. NEWMAT
4. EDIT
5. LBL 00
6. RCLIJ
7. X=Y?
8. GTO 01
9. XEQ “R10”
10. →
11. GTO 00
12. LBL 01
13. SIGN
14. STOEL
15. STOIJ
16. I+
17. FC? 76
18. GTO 00
19. CLX
20. EXITALL
21. END
0. { 22-Byte Prgm }
1. LBL “MMOD”
2. EDIT
3. LBL 00
4. RCL ST Y
5. MOD
6. →
7. FC? 77
8. GTO 00
9. EXITALL
10. END
0. { 34-Byte Prgm }
1. LBL “A→M”
2. ALENG
3. RCL/ ST Y
4. ENTER
5. FP
6. X>0?
7. SIGN
8. +
9. X<>Y
10. NEWMAT
11. EDIT
12. LBL 00
13. R↓
14. ATOX
15. →
16. FC? 77
17. GTO 00
18. EXITALL
19. END
0. { 95-Byte Prgm }
1. LBL “HILL”
2. INPUT “RMAX”
3. INPUT “SHIFT”
4. INPUT “CYMOD”
5. INPUT “MSIZE”
6. XEQ “LTRI”
7. ENTER
8. ENTER
9. TRANS
10. *
11. RCL “CYMOD”
12. X<>Y
13. XEQ “MMOD”
14. STO “INMAT”
15. R↓
16. X<>Y
17. FIX 00
18. INVRT
19. RND
20. ALL
21. ENTER
22. TRANS
23. X<>Y
24. *
25. XEQ “MMOD”
26. STO “OUTMAT”
27. END
CYMOD 26
All to all: SHIFT 0
CYMOD 256
0. { 85-Byte Prgm }
1. LBL “ENCY”
2. RCL “INMAT”
3. GTO 00
4. LBL “DECY”
5. RCL “OUTMAT”
6. LBL 00
7. ENTER
8. DIM?
9. X<>Y
10. R↓
11. XEQ “A→M”
12. X<>Y
13. *
14. RCL+ “SHIFT”
15. RCL “CYMOD”
16. X<>Y
17. XEQ “MMOD”
18. RCL+ “SHIFT”
19. LBL “M→A”
20. CLA
21. XTOA
22. AVIEW
23. END
