Full Version: Complex number notation - transform from rectangular to polar
Hello
Simple question here.
How do I transform a complex number from the rectangular a+i*b notation to the r<ยข notation (polar notation) in the HP Prime CAS. [/code]
Thanks
Only in Home mode: enter coordinates then use [shift] [X] to switch between the coordinate type (in the history screen). Shift X is the angle sign.
-Dale-
Shift X is also fine to enter polar number :
100 Shift X 45
polar_coordinates
Many thanks for the responses
The CAS command polar_coordinates worked like a charm!
