12-25-2013, 04:48 PM
Following up on a HP28s example made by Damien in another sub-forum, I thought to try to do the same on the Prime.
Damien's examples and explanation:
A(a, a'), B(b, b'), C(c, c') are lined up if the determinant = 0
|a a' 1|
|b b' 1| = 0
|c c' 1|
Examples:
(2,2)
(4,1)
(5,3) -> The points are not colinear
(2,-3)
(4,1)
(5,3) -> The points are colinear
The program must be run in Textbook or Algebraic as if not the calculator will crash, so to avoid that I preserve the Entry mode in a local variable and reinstate it at the end. It is also only relevant to 3 points and does not check if more points have been entered in the matrix editor.
However, when running the program off the stack whilst in RPN mode it always return a 2 (which is the Entry state) to the stack. I have looked but cannot find a way to avoid this undesired result in the program. Does anybody have a suggestion for how this could be achieved?
Cheers, Terje
|a a' 1|
|b b' 1| = 0
|c c' 1|
Examples:
(2,2)
(4,1)
(2,-3)
(4,1)
EXPORT COLINEAR()
// Declare local variable to hold matrix and state
LOCAL Points,s;
// Preserve entry mode and set to textbook
s:=Entry;
Entry:=0;
// Create input matrix 3 rows by 2 cols
Points:=[[0,0],[0,0],[0,0]];
// Allow input of points and add column of one's to make square
EDITMAT(Points);
ADDCOL(Points,[1,1,1],3);
// Check if determinant is equal to 0 and display result in MSGBOX
IFERR 1/det(Points)
THEN MSGBOX("The points are colinear")
ELSE MSGBOX("The points are not colinear")
// Reinstate entry mode
Entry:=s;
Cheers, Terje
