Thanks for replying.
Running Linux Mint 20.2 (Ubunto 20.04).
( cd qemu/qemu-git; \
./configure-small --extra-cflags=-DX49GP; \
make -f Makefile-small )
Source path /home/sergio/x49gp/qemu/qemu-git
C compiler gcc
Host C compiler gcc
CFLAGS -O2 -g
QEMU_CFLAGS -Werror -m64 -Wold-style-definition -Wold-style-declaration -I. -I$(SRC_PATH) -U_FORTIFY_SOURCE -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -Wstrict-prototypes -Wredundant-decls -Wall -Wundef -Wendif-labels -Wwrite-strings -Wmissing-prototypes -fno-strict-aliasing -DX49GP
LDFLAGS -Wl,--warn-common -m64 -g
make make
host CPU x86_64
host big endian no
target list arm-softmmu
tcg debug enabled no
gprof enabled no
sparse enabled no
strip binaries yes
profiler no
static build no
-Werror enabled yes
mingw32 support no
Block whitelist
preadv support yes
fdatasync yes
make[1]: se entra en el directorio '/home/sergio/x49gp/qemu/qemu-git'
GEN arm-softmmu/config-devices.mak
GEN config-all-devices.mak
GEN config-host.h
CC cutils.o
CC qemu-malloc.o
CC tcg-runtime.o
CC host-utils.o
GEN config-target.h
CC arm-softmmu/exec.o
CC arm-softmmu/translate-all.o
CC arm-softmmu/cpu-exec.o
CC arm-softmmu/translate.o
CC arm-softmmu/tcg/tcg.o
In file included from /home/sergio/x49gp/qemu/qemu-git/tcg/tcg.c:158:
/home/sergio/x49gp/qemu/qemu-git/tcg/tcg.c: In function ‘tcg_reg_alloc_call.isra.0’:
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1201:45: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1201 | tcg_out_modrm(s, 0x8b, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/tcg.c:1690:17: note: while referencing ‘func_arg’
1690 | TCGArg arg, func_arg;
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1190:54: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1190 | tcg_out_modrm(s, 0x63 | P_REXW, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1187:62: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1187 | tcg_out_modrm(s, 0xbf | P_EXT | P_REXW, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1184:62: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1184 | tcg_out_modrm(s, 0xbe | P_EXT | P_REXW, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1146:28: error: array subscript 3 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1146 | args[3], P_REXW);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1145:9: error: array subscript 1 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1145 | tcg_out_brcond(s, args[2], args[0], args[1], const_args[1],
/home/sergio/x49gp/qemu/qemu-git/tcg/tcg.c:1693:9: note: while referencing ‘const_func_arg’
1693 | int const_func_arg, allocate_args;
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1145:9: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1145:31: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1116:23: error: array subscript 2 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1116 | if (const_args[2]) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1117:21: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1117 | if (args[2] == 1) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1121:33: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1121 | tcg_out8(s, args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1083:48: error: array subscript 4 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1083 | tcg_out_modrm(s, 0xf7 | P_REXW, 6, args[4]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1080:48: error: array subscript 4 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1080 | tcg_out_modrm(s, 0xf7 | P_REXW, 7, args[4]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1059:23: error: array subscript 2 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1059 | if (const_args[2]) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1070:66: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1070 | tcg_out_modrm(s, 0xaf | P_EXT | P_REXW, args[0], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1061:23: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1061 | val = args[2];
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1036:23: error: array subscript 2 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1036 | if (const_args[2]) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1039:60: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1039 | tcg_out_modrm(s, 0x01 | (c << 3) | P_REXW, args[2], args[0]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1037:46: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1037 | tgen_arithi64(s, c, args[0], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:996:70: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
996 | tcg_out_modrm_offset(s, 0x89 | P_REXW, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:996:61: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:975:70: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
975 | tcg_out_modrm_offset(s, 0x8b | P_REXW, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:975:61: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:971:70: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
971 | tcg_out_modrm_offset(s, 0x63 | P_REXW, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:971:61: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:962:78: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
962 | modrm_offset(s, 0xbf | P_EXT | P_REXW, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:962:69: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
962 | tcg_out_modrm_offset(s, 0xbf | P_EXT | P_REXW, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:949:78: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
949 | modrm_offset(s, 0xbe | P_EXT | P_REXW, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:949:69: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
949 | tcg_out_modrm_offset(s, 0xbe | P_EXT | P_REXW, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:936:52: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
936 | tcg_out_movi(s, TCG_TYPE_I64, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1198:53: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1198 | tcg_out_modrm(s, 0xb7 | P_EXT, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1194:65: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1194 | tcg_out_modrm(s, 0xb6 | P_EXT | P_REXB_RM, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1181:53: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1181 | tcg_out_modrm(s, 0xbf | P_EXT, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1178:65: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1178 | tcg_out_modrm(s, 0xbe | P_EXT | P_REXB_RM, args[0], args[1]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1142:28: error: array subscript 3 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1142 | args[3], 0);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1141:9: error: array subscript 1 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1141 | tcg_out_brcond(s, args[2], args[0], args[1], const_args[1],
1142 | args[3], 0);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1141:9: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1142 | args[3], 0);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1141:31: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1089:23: error: array subscript 2 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1089 | if (const_args[2]) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1090:21: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1090 | if (args[2] == 1) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1094:33: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1094 | tcg_out8(s, args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1077:39: error: array subscript 4 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1077 | tcg_out_modrm(s, 0xf7, 6, args[4]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1074:39: error: array subscript 4 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1074 | tcg_out_modrm(s, 0xf7, 7, args[4]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1044:23: error: array subscript 2 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1044 | if (const_args[2]) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1055:57: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1055 | tcg_out_modrm(s, 0xaf | P_EXT, args[0], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1046:23: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1046 | val = args[2];
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1014:23: error: array subscript 2 is outside array bounds of ‘int[1]’ [-Werror=array-bounds]
1014 | if (const_args[2]) {
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1017:51: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1017 | tcg_out_modrm(s, 0x01 | (c << 3), args[2], args[0]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:1015:46: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
1015 | tgen_arithi32(s, c, args[0], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:992:61: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
992 | tcg_out_modrm_offset(s, 0x89, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:992:52: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:987:61: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
987 | tcg_out_modrm_offset(s, 0x89, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:987:52: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:981:72: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
981 | tcg_out_modrm_offset(s, 0x88 | P_REXB_R, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:981:63: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:967:61: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
967 | tcg_out_modrm_offset(s, 0x8b, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:967:52: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:958:69: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
958 | tcg_out_modrm_offset(s, 0xbf | P_EXT, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:958:60: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:954:69: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
954 | tcg_out_modrm_offset(s, 0xb7 | P_EXT, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:954:60: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:945:69: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
945 | tcg_out_modrm_offset(s, 0xbe | P_EXT, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:945:60: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:941:69: error: array subscript 2 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
941 | tcg_out_modrm_offset(s, 0xb6 | P_EXT, args[0], args[1], args[2]);
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:941:60: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
/home/sergio/x49gp/qemu/qemu-git/tcg/x86_64/tcg-target.c:933:62: error: array subscript 1 is outside array bounds of ‘TCGArg[1]’ {aka ‘long unsigned int[1]’} [-Werror=array-bounds]
933 | tcg_out_movi(s, TCG_TYPE_I32, args[0], (uint32_t)args[1]);
cc1: all warnings being treated as errors
make[2]: *** [/home/sergio/x49gp/qemu/qemu-git/rules.mak:18: tcg/tcg.o] Error 1
make[1]: *** [Makefile-small:69: subdir-arm-softmmu] Error 2
make[1]: se sale del directorio '/home/sergio/x49gp/qemu/qemu-git'
make: *** [Makefile:167: qemu/qemu-git/config-host.h] Error 2
