10-15-2014, 06:48 PM
This WP-34S benchmark code is courtesy of Patrice Torchet:
Performance statistics using WP34S Firmware version 3.3 on HP-30B Hardware for the "Traditional" WP-34S NQueens Benchmark (See Xerxes Article)
WP-34S "Traditional" mode: [f] H.d (DECM):------------------------>68 Ticks
WP-34S "Traditional" mode: BASE 10 : -----------------------------> 61 Ticks
Performance statistics using WP34S Firmware version 3.3 on HP-30B Hardware for the code below are as follows:
Torchet WP-34S N-Queens Optimized:-------------------------------------------->21 Ticks
There are approximately 10 Ticks per second
140 [f] LBL C
141 TICKS
142 STO K
143 [f] BASE 16
144 WSIZE 32
145 [h] CLx
146 STO C //loop counter
147 STO I //Stack pointer
148 1
149 0
150 1
151 0
152 1
153 0
154 1
155 STO A //0x1010101
156 8
157 STO B //remaining Q
158 [h] MASKR 08
159 [h] SL 01
160 STO 00 //0x1FE
161 [f] LBL 02 //x=bitmap y=Q position
162 INC C
163 [h] BS?->Y //test Q position
164 [h] GTO 05 //Q OK, next line
165 [f] LBL 03 //x=bitmap y=Q position
166 [h] DSZ Y //SHIFT QUEEN
167 [h] GTO 02 //RETRY
168 INC B //ootherwise backtrack
169 RCL->I //pop a Q
170 DEC I //pop a Q
171 RCL->I //pop a Q
172 DEC I //pop a Q
173 [h] GTO 03
174 [f] LBL 05 //x=bitmap y=Q position
175 INC I
176 STO->I //Save bitmap
177 X<>Y
178 INC I
179 STO->I //save Q
180 X<>Y
181 DSZ B //Finish if 0
182 [h] GTO 01
183 [h] GTO 04
184 LBL 01
185 RCL A //get Q mask
186 [h] RL->Z //shift
187 [h] OR //merge with bitmap
188 RCL 00
189 [h] NOT
190 [h] AND //clear combination
191 [h] RR 09
192 [h] RRC 08 //shift diagonal
193 RL 16
194 [h] RLC 08 //shift diagonal
195 [h] RR 07
196 ENTER
197 ENTER
198 [h] RL 08
199 [h] OR //ORing L V R
200 ENTER
201 [h] RL 16
202 [h] OR //ORing L V R
203 RCL 00
204 [h] AND //mask Combination
205 RCL L
206 [h] XOR //negate Combination
207 [f] X=0? //if 0
208 [h] GTO 06 //deadend
209 [h] OR //merge Combination to bitmap
210 8
211 X<>Y
212 [h] GTO 02
213 [f] LBL 06 //Shortcut
214 8
215 STO+C
216 INC B
217 RCL->I
218 DEC I
219 RCL->I
220 DEC I
221 [h] GTO 03
222 [f] LBL 04
223 RCL C
224 BASE 10
225 TICKS
226 RCL K
227 -
228 STO K
229 R Dn
230 [g] RTN
bitmap principle
the bitmap contains 4 parts of 8 bits
L Left diagonal locks
V Vertical locks
R Right diagonal locks
C Combination = L or V or R This is the part tested (BS?)
LLLLLLLVVVVVVVVRRRRRRRRCCCCCCCCL
register A
00000001000000010000000100000001
bitmap is rotated to have combination on bits 1 to 8
register A is rotated too to match bitmap
