Full Version: Doubt with List Excell from Spreadsheet HP Prime
How I make list similar excel in the spreadsheet HP Prime?
I need command similar to excel that can I choose and print in celula .
Below I have one file for example.
Can you help me,please!!
Best regards!
Elton Freitas
The Prime 'Spreadsheet' App is in many ways more powerful than Excel (e.g. storing lists and matrixes in single cells and using them in calculations), but at the same it is more limited. No printing, for example.
It is not clear from your attached file what you want to do, as it is an image of a spreadsheet with no calculations, etc., but with Prime, you can have a 'named' variable in a cell or a range of values with the 'name' in the column header and use those to calculate with a formula.
The Quick Start User's Guide will get you started and the full User's manual will provide more advanced help.
There is currently no way to make a drop down chooser in the spreadsheet. All the pieces are there to make it possible, so i wouldn't expect it to be too incredibly difficult to implement. I've put it on the list of potential future enhancements.
Thanks!
For don't stay more doubts. I send for everybody a file to explain the command for me conclude my project.
Thanks
Best Regards,
Elton Freitas
