Thanks for comments on the 2nd batch V3 units.
(01-10-2015 09:34 PM)rwiker Wrote: [ -> ] (01-10-2015 09:04 PM)BobVA Wrote: [ -> ]Arrived safe and sound - thanks! (The new silk screen does look very nice.)
I got mine today - just the day after I bought batteries in hope of getting the kit sometime next week :-)
Bob got units from both batches and will notice the silkscreen difference.
The silkscreen on this batch did looks better than the 1st batch. I compared and this batch appears to have "thicker" font prints. I am at the mercy of my PCB fabricator and does not know why it is not consistent. May be they have introduce new machines. Actually I spent good time to draw all the math symbols for the V2 PCBs and they got messed up and cannot print them, you can see the different from the pictures on page 1 or 2.
(01-10-2015 11:37 PM)PANAMATIK Wrote: [ -> ]I got mine today here in germany. But I don't have batteries and will get them on monday, I forgot buying, despite your reminding.
It's smaller than I thought and it looks very, very nice. The smallest three in one HP calculator ever.
Bernhard
Yes, It meant more as a toy than something to use for everyday work. Another reason for the weird (and smaller) size is that it cost less to produce the PCBs.
This shipping is faster than expected. Could be that it's after Christmas? I would imagine the kits are also getting into their builders hands. There are 3 kits in this batch and I had wrote up advise for the single kit ordered on the 1st batch, So kit builders for 2nd batch can also use. I will re-type as follows
"There are some build tips for my "other" calculator which also applies to the NP-25
http://forum.43oh.com/topic/5524-tms0803...d/?p=49241
The tactile buttons must be bend by using a pair or long nose pliers. The holes are still a bit large so it fits loosely and you might need to align the buttons while soldering one side of it.
The buttons are SMD parts and I found that using thru-hole PCB allow me to "fit" them on the PCB so there is no need to use stencils and I can have a "flat" bottom.
I would recommend you to solder the ICs before the displays. ICs need to be cut short on one side. The LED displays are very tricky to align properly and they are designed to be tilted at a angle (see datasheet found in sparkfun product page). I would solder everything and then "friction fit" the leds w/o soldering them. Turn it on and based on the display use a pair of twitters to adjust the final position / angle of the leds before soldering them.
If I got a chance to re-do this, I am going to try to get everything on one side for easier assembly."
The link to 43oh you will not see photos unless you are a member. But please do read the text I post there (as simpleavr) especially about aligning the LED and IC parts (pin 1 position).
Another tip that I just developed doing the 2nd batch assembly is to find yourself a perfboard, and test fit the LED modules on it before fitting them onto the NP-25 PCB. Perfboard will have larger holes. You can adjust the pins, set the LED module on the perfboard, rock it back and forth, lift it up and down. When you reach a point that no pin is resisting when you lift it out of the perfboard, the alignment is at its best. This will allow way easier final fitting and better consistency on all the 3 led modules.
Please feel free to post any question regarding the build.
Also update for next batch.
V3 3rd batch list
rposperi x3, Marcus (k), Geoff, jebem (k), walter, Den, RMollov, Herman (10 units)
