Full Version: I41cx (iPhone/iPad) issue with Advantage Pac HEXIN implementation?
Ran into this last night while setting up the i41cx app, and wondering if anyone else has seen this.
I’ve loaded the Advantage module from the UI — swipe, touch the modules, spin to ADVANTAGE, and load. I’m pretty sure it’s loading the B revision of the Advantage Pac.
Using HEXIN, I’m not getting hex to decimal conversions — I seem to be getting junk; it looks like it’s incrementing some counter each conversion and outputting the result.
If I recall correctly, there’s no equivalent of word size on the Advantage Pac implementation the way there is with the 16C; everything works with sixteen bits, I think.
Does this ring a bell for anyone? Does anyone remember a HEXIN bug in some version of the pac that may be what i41cx is loading?
FWIW, the DM41X Advantage Pac does not have this bug — I was setting up my iPhone app to match the key bindings on my DM41X just for fun.
Curious minds want to know.
