03-07-2024, 03:31 AM
I probably stretched my overlay a bit when I pulled it out of the package so it tends to bow in the middle when attached to my HP 12C running the HP 15CE firmware in 16C mode.
I found that narrow strips of Scotch brand "Removable" double sided tape laid horizontally between the rows of keys work well in taming the bow. It moves the bow to the edges but it is a better solution for me. The adhesive is weak enough that the overlay can be repositioned but it still lifts up a little bit here and there.
The "Removable" tape is an important distinction as Scotch also sells a "Permanent" double sided tape product which is probably to sticky for my use and might tear the overlay if it needed to be removed.
