My Prime keeps rebooting when connected to my pc when i try to use the connectivity kit. Latest firmware is installed (20230413). I haven't had this problem before so i think maybe i should try to downgrade the firmware?
Any tips on how I can do this?
This is a known issue occurring on G1.
Just perform a memory clear (ON + APPS + ESC). This will delete all data, but it will resolve the issue, allowing you to work with the Connectivity Kit properly. If you had cleared the data before upgrading to the new firmware, the problem would not have occurred.
Piotr
(03-07-2024 01:25 PM)komame Wrote: [ -> ]This is a known issue occurring on G1.
Piotr
I'm trying to downgrade the FW also but i cant seem to do that, is there any way i can find older FW versions, i found an old post about this but the links don't work anymore..
