02-29-2024, 01:18 PM
Since a good photomicrograph of the 1LK7 Saturn CPU chip (as used in the 18C, 28C, and the late 71B) has recently been made available, I thought it might be nice to find the earlier 1LF2 CPU chip (used in the early 71B) to desolder, and send off for decap and photomicrograph. I'm expecting them to be very similar. The 1LK7 adds two instructions for Saturn architecture level 1, so I expect that the 1LF2 instruction decode PLA will have a few less terms. The 1LK7 might be in the newer HP CMOSG process, whereas I think the 1LF2 was in CMOSC. The I/O buffers and analog circuitry might be different.
I have been hoping to find a cheap non-working 71B to sacrifice, but I've only seen TAS listing for working, for high prices, and untested, for nearly as high prices.
For a unrelated reason, I just went through boxes of calculators that I brought when I moved in 2012, and which have been almost untouched since. (Unfortunately I wasn't able to bring my entirecollection.) I do have four 71B, with serial prefixes of 2523A, 2635A (which had had a rough life), , and two 2845A. The 2845A both have 2CDCC ROM, and probably 1LK7 CPUs. The 2635A has 1BBBB, and probably the 1LF2.
While all four were working when I packed them away, the 2635A now shows no signs of life. I think it probably has 1BBBB with a 1LF2, but I haven't yet opened it. It is in physically pretty good shape. I'm thinking about sacrificing the CPU chip; hopefully there is little or no ESD damage to it.
Based on the appearance of the bottom plate, I think it has the older style construction, compared to the other three, so I'm not yet sure whether I can swap the housing with the 2635A. But at least I may wind up with spare hybrids from inside the 2635A, if they're not damaged.
Anyhow, I'm potentially interested in broken or beat-up 71B and accessories (especially. HPIL module) for decap and photo. The HPIL module is especially interesting because it has a custom HP microcontroller with HPIL, which provides the mailbox interface over the Saturn bus. It's may be related to the processor in the Thinkjet.
I used to have a lot of HP-IL cables, and am dismayed that I now only seem to have three. Sigh.
