Dear all,
I try to communicate with my HP 3421A Data Acquisition Control, using a HP75D. In an HP manual 'Programming the HP 3421A with the Hp·71B and the Hp·75D the following program is suggested for the HP75D:
10 ! DCV HP 75/3421A
20 REAL V
30 CLEAR LOOP
40 D=DEVADDR(' :E1')
50 OUTPUT D ; "DCV5"
60 ENTER D ; V
70 DISP V
80 END
However, I get an error message for line 40: error extra characters.
My ASSIGNIO was: Device # 1=':E1'
Furthermore OUTPUT gives a syntax error.
These statements, however, are valid for my HP71B, where
40 D=DEVADDR("HP3421A")
So, I am a little confused. I looked at the manuals, but could not find the clou.
Does anyone of you has experience with the combination HP75C,D and a datalog system?
Thanks,
Henk Schellen
(02-27-2024 08:57 PM)hesc Wrote: [ -> ]40 D=DEVADDR(' :E1')
I have an HP-75D but no HP3412A so I can't try the program. But can it be that the "extra character" is the blank space in front of :E1 ? I found the original listing online and there it says ':E1'
Would be an almost too simple soiution...
Max
60 ENTER D ; V
A silly question, but do you have the HP-75 I/O module installed ?
J-F
Kind of a punt, but if it is the only device on the loop, don't you know its address is 1?
Don't bother with line 40 or variable D.
Maximilian and Jean-François have the solution.
Quote:Programming the HP 3421A with the HP-75D (using OUTPUT's and ENTER's) requires that the I/O ROM (part number 00075-15001) be installed in your HP-75D.
Quote:This section will also assume for simplicity that the minimum configuration consists of an HP-75D (with the I/O ROM) and an HP 3421A, and that the maximum configuration consists of the HP-75D, 3421A, printer (either an HP 82162A or an HP 2225B), and a mass storage device (either an HP 82161A or an HP 9114A).
If you have one of these configurations, and you have executed an ASSIGN LOOP (or AUTOLOOP ON) statement, the HP-75D should assign the following device codes:
Assuming only one device in the loop
:E1 3421A Data Acquisition Unit
Your program but without the space between the single quote and the colon.
20 REAL V
30 CLEAR LOOP
40 D=DEVADDR(':E1')
60 ENTER D ; V
70 DISP V
80 END
Dear all,
In my HP75C a data communications ROM is installed, 00075-15035. In my other HP75D I see 2 empty slots and the third one is occupied by a rather large tele communications unit around the HP75D, I believe.
So, I think indeed, the missing IO module in both HP's may be the problem...
Thank you all for solving the problem.
Kind regards,
Henk
You beat me Dave...
And wow, you're up late! Or maybe up early!
(02-28-2024 08:37 AM)hesc Wrote: [ -> ]In my other HP75D I see 2 empty slots and the third one is occupied by a rather large tele communications unit around the HP75D, I believe.
That should be the 82718A Expansion Pod.
(02-28-2024 11:14 AM)Dave Frederickson Wrote: [ -> ]If you don't have an I/O ROM you can use the I/O Utilities.
Yep!
But it does not contains the autoloop keyword, so you will have to do it manually.
assignio ':E1'
assignio ':P1,:M1'
OUTPUT will also be missing, only SENDIO, ENTIO$ & SEND? commands are part of this lex file.
These are lower level than OUTPUT, I do not have the time to do this right now, but later I can rework your test program to use these keywords instead.
Other than here, there is a
HP-75 users group that can answer your questions and have all the documents regarding that machine.
(02-28-2024 01:27 PM)rprosperi Wrote: [ -> ]You beat me Dave...
Yeah, couldn't sleep.
Thanks to you for contributing the LIF file to the HP Computer Museum.
Thanks for your help!
Henk
I have tried your program with my equipment and it works. (75C, I/O ROM & 3421A)
Program listing (assuming AUTOLOOP is enabled)
20 REAL V
30 D=DEVADDR(':E1')
40 CLEAR LOOP
60 ENTER D ; V
70 DISP V
80 END
Since you do not have the I/O ROM, the following keywords are not available: AUTOLOOP, DEVADDR , OUTPUT & ENTER
Loading the HPILCMDS lex file adds the following keywords: SENDIO, ENTIO$ & SEND?
Although, SENDIO and ENTIO$ keywords are lower level than the OUTPUT and ENTER keywords, the lex file is still doing some HP-IL house keeping behind.
So here is the modified program listing
20 REAL V
30 ASSIGN IO ':E1'
40 CLEAR LOOP
50 SENDIO ':E1','LAD#','DCV5'&CHR$(13)&CHR$(10)
60 V = VAL(ENTIO$(':E1','TAD#,SDA'))
70 DISP V
80 END
These manuals covers HP-IL interface and protocol:
edit: typo
(02-28-2024 08:37 AM)hesc Wrote: [ -> ]In my HP75C a data communications ROM is installed, 00075-15035. In my other HP75D I see 2 empty slots and the third one is occupied by a rather large tele communications unit around the HP75D, I believe.
https://www.hpmuseum.net/display_item.php?sw=489
https://literature.hpcalc.org/community/...-io-en.pdf
I just realized that the I/O utilitiy commands (SENDIO, ENTIO$, SEND?) are included in the Data Communications ROM !
It is the way the BASIC programs inside this ROM communicate with the HP-IL modem and printers.
So Sylvain's program can be entered and used with just your Data Comm module inserted:
(03-03-2024 08:26 PM)Sylvain Cote Wrote: [ -> ]So here is the modified program listing
20 REAL V
30 ASSIGN IO ':E1'
40 CLEAR LOOP
70 DISP V
80 END
Let us know if this works.
J-F
Dear Dave and Sylvain,
I got a syntax error for the SENDIO command. The communication modem, however, is not power supplied, i.e. it has no batteries, nor an external power supply. Could that be the problem?
Kind regards,
Henk
Hello Henk,
(03-07-2024 08:18 PM)hesc Wrote: [ -> ]I got a syntax error for the SENDIO command.
I think you did not understood Jean-François suggestion.
What he is proposing is that you:
- plug your data communication ROM into the 75
- with HP-IL cables, connect the 75 to the 3421A
- enter my program
- run my program
Best regards,
Sylvain
(03-07-2024 08:18 PM)hesc Wrote: [ -> ]Dear Dave and Sylvain,
Kind regards,
Henk
The modem is not an HP-IL device, so as long as the computer is running, HP-IL communication should work whether its batteries are charged or not. If the batteries are flat, you may get an error.
Hello Sylvain,
Sorry, I thought the 75D with modem had a data communications module inside.
In my 75C a data communications module is available. I have run your program on it and it works, indeed!
Thanks,
Henk
