09-14-2014, 09:24 PM
This is a trick I've found to define a new symbolic constant (typically transcendental, or with no proof to the contrary) for use in algebraics; that is, the symbol is unchanged on EVAL but changes to its approximate value with →NUM. In this example, we define the Euler--Mascheroni constant gammaE = 0.577...
First, define the program SYMBCONST:
Now define gammaE:
To see this at work:
This trick relies on →NUM changing the \pi to 3.14159265359 in the second argument to SYMBCONST; it holds no other special meaning. (A more elegant solution would be to find some way to hook →NUM.) More constants can be added with additional clauses in SYMBCONST's CASE.
« → n x
IF x '\pi' SAME
THEN n
ELSE
CASE n 'gammaE' SAME
THEN 0.577215664902
END
END
END
Now define gammaE:
« 'SYMBCONST(QUOTE(gammaE),\pi)' EVAL »
'SIN(gammaE)' EVAL → 'SIN(gammaE)'
'SIN(gammaE)' →NUM → 0.5456928233204
