For anyone out there who has and will implement HP-25 emulators, how about ading GSB and RTN commands using line numbers at least? There are aviable shift keys for these two commands on the HP-25 keyboard.
Namir
RPN-25 from CuVee Software appears to do precisely that:
http://www.cuveesoft.ch/rpn25/
In addition to a whole bunch of other added features, such as labels.
For an implementation using original program tokens, there are only 16 free, so that would limit the GSB line numbers.
Namir,
(02-06-2024 04:51 PM)Namir Wrote: [ -> ]For anyone out there who has and will implement HP-25 emulators, how about ading GSB and RTN commands using line numbers at least? There are aviable shift keys for these two commands on the HP-25 keyboard.
You asked the very same question about the
HP-12C in another thread. It's not a question of available
locations on the keyboard,
Namir, it's a question of
available keycodes.
In both the
HP-12C and the
HP-25, each programmable instruction occupies one byte, i.e.
one keycode of the 256 available. If you were to add
GSB to any of those machines you'd need
50 keycodes for
GSB 01 to
GSB 49 (
HP-25) plus
RTN, and you simply do not have that many available, only
16 are unused as
Teenix just said.
This is also the reason why on the
HP-12C, even though there are
20 data registers available (
R0 to
R9 and
R.0 to
R.9) (
Owner's Handbook p.24)
Storage register arithmetic (STO+, STO-, STOx, STO/) is possible with only registers
R0 to
R4.
Why ? Because there aren't enough keycodes available for
R5 and beyond, let alone for
GSB 01 to
GSB 99. On the other hand, the
HP-15C programmable instructions (
700 in all) can use
one or
two bytes of program memory and this solves the problem of keycode availability.
Regards.
V.
Is there a drawback to using an HP-29C emulato? The HP-29C is for the most part a superset of the HP-25, and has LBL and GSB.
(02-06-2024 09:59 PM)teenix Wrote: [ -> ]For an implementation using original program tokens, there are only 16 free, so that would limit the GSB line numbers.
How does the HP-33E/C handle this?
(02-07-2024 12:45 AM)Thomas Okken Wrote: [ -> ]How does the HP-33E/C handle this?
They have GSB 01 -> GSB 49 in the program token set.
The 25 wastes a lot of tokens with X Y comparisons being hard coded like if X = Y GTO 00, if X <= Y GTO 01 etc, whereas the 33C skips a following GTO N token depending on the comparison result.
If the 25 had similar tokens, then there would be a lot more for GSB's. I guess though that the designers thought why bother with such a limited 49 step program space and there might not have been the ROM space to implement it.
cheers
Tony
Well, if there's 16 free opcodes, that would be enough to add a few:
GSB 30
GSB 40
RTN
i.e. only support GSB to a few specific line numbers. Then you could have one or two small subroutines, which can occasionally make sense with a 49-step program memory.
(02-06-2024 11:55 PM)brouhaha Wrote: [ -> ] (02-06-2024 04:51 PM)Namir Wrote: [ -> ]For anyone out there who has and will implement HP-25 emulators, how about ading GSB and RTN commands using line numbers at least? There are aviable shift keys for these two commands on the HP-25 keyboard.
This was my thought too. However, the conditional test set is different, as discussed for instance
here.
If for some reason a 25C+ with GSB/RTN is desired, it may be easier to start from the 29C and change the conditionals to the 25C set.
Also, the SST/BST placement should be aligned to the 25C. So updating a physical 25C to a 25C+ (or could we name it 26C ? a never-used model number) would just involve putting a few labels for the new g-functions.
J-F
(02-07-2024 01:00 AM)teenix Wrote: [ -> ]The 25 wastes a lot of tokens with X Y comparisons being hard coded like if X = Y GTO 00, if X <= Y GTO 01 etc, whereas the 33C skips a following GTO N token depending on the comparison result.
No. On the HP-25, comparisons and GTO are separate instructions, taking up 8 and 50 opcodes, respectively.
(02-07-2024 10:16 AM)Thomas Okken Wrote: [ -> ]No. On the HP-25, comparisons and GTO are separate instructions, taking up 8 and 50 opcodes, respectively.
Sorry, I had the wrong data file open, it was for the HP-55
The 25 has 63 spare program codes according to my info. That would mean you could implement GSB 01 -> 49 and have RTN as well.
(02-07-2024 11:04 AM)teenix Wrote: [ -> ] (02-07-2024 10:16 AM)Thomas Okken Wrote: [ -> ]No. On the HP-25, comparisons and GTO are separate instructions, taking up 8 and 50 opcodes, respectively.
That doesn't sound quite right either. On my 55, GTO takes up a single step (displayed as the line number to branch to, but negative). The comparisons are simply f GTO or g GTO, and appear as such, so x<=y? GTO 20 is two steps: 31, -20 (f GTO 20).
Is there a document that has all the opcode tables for the keystroke-programmable models? I'm kind of curious how some of the other models have allocated things.
(02-07-2024 01:51 PM)Dave Britten Wrote: [ -> ]Is there a document that has all the opcode tables for the keystroke-programmable models?
There is:
Obscure internal details of HP calculators
- Hex tables of internal byte codes for user program steps
Unfortunately, the
HP-25 is missing.
I owe a lot of you a big apology! I used the word emulator when I really meant simulator, since the last is not tied to the calculator's origiinal byte/key code. Using simulators give developers much freedom to add features and functions. Cuveesoft is a good example of a developer who implements interesting simulators with added features.
Again, oooops!
Namir
(02-07-2024 04:18 PM)Thomas Klemm Wrote: [ -> ] (02-07-2024 01:51 PM)Dave Britten Wrote: [ -> ]Is there a document that has all the opcode tables for the keystroke-programmable models?
There is: Obscure internal details of HP calculators
Unfortunately, the HP-25 is missing.
Thanks, the 11C looks about like I was expecting, i.e. packed to the gills.
The 25 presumably had so many unused opcodes because every last byte of the ROM was filled, and there simply wasn't room to implement any more instructions!
(02-07-2024 01:51 PM)Dave Britten Wrote: [ -> ]That doesn't sound quite right either. On my 55, GTO takes up a single step (displayed as the line number to branch to, but negative). The comparisons are simply f GTO or g GTO, and appear as such, so x<=y? GTO 20 is two steps: 31, -20 (f GTO 20).
Apologies, I was trying to refer to the program tokens used for the comparison functions
55
49 x GTO - GTOnn
49 x if X<=Y then GTO - [f][GTO]nn
49 x if X=Y then GTO - [g][GTO]nn
The 33 was better in that comparisons used 1 token each, then they can use any of the GTO codes as a branch if TRUE.
33
49 x GTO - GTOnn
f X<=Y
f X>Y
f X!=Y
f X=Y
g X<=0
g X>0
g X!=0
g X=0
So, there is a big token saving, 147 vs 57 (plus there are 6 extra comparisons) The [f] and [g] keys also used one extra in the 55 and not in the merged keycode 33.
I think I would need to see the 55 opcode table to fully grasp your meaning. As far as I'm aware, there are simply 49 different GTO opcodes, and an f or g prefix in the previous step is what changes its meaning from an unconditional to a conditional branch.
You are correct. Somehow, back when I first started fiddling with a 55 emulator, I have a program token map that is incorrect. Unlikely now that I'll find out why, but I will amend it. Thankyou.
cheers
Tony
No problem! Took me a bit to wrap my head around what the hell the 55 was doing with conditionals when I first got it.
