01-14-2024, 04:01 PM
Introduction
Recently I stumbled upon the book Compilerbau by Niklaus Wirth.
A small language PL/0 is used to illustrate how to write an interpreter and a compiler.
For the compiler a stack-based machine is assumed.
Thus I wondered if an HP-calculator could be used as target.
There's a PL/0 Language Tools project but it appears to be abandoned.
The last commit on the GitHub repository was made 7 years ago.
It is still based on Python 2 which is now dead.
The Language PL/0
It is a simplified variant of Pascal with the following EBNF:
Installation and Setup
Download Project
Download the ZIP-file and unzip it.
unzip pl0-compiler.zip
It should contain the following files:
Setup the Virtual Environment
python3 -m venv venv
source venv/bin/activate
pip install --upgrade pip setuptools wheel
pip install ply
Programs
Some example programs can be found in the examples directory.
Fibonacci
Compile to HP-42S
The program pl0_hp42s.py is based on pl0_compiler.py and creates commands for the HP-42S:
python pl0_hp42s.py examples/fibonacci.pl0
Caveat
Input Output
For input and output use ? and !:
?n; ?k; CALL perm; !p
Syntax
The syntax for comparisons is slightly changed.
Instead of = for equal use ==.
Instead of # for not equal use !=.
Integer Division
It is assumed that the machine uses only integers.
Therefore division results in integers.
However I find it more useful to use the ordinary division on an HP-42S.
It is easy to include the IP command if that is needed.
Or then replace ÷ by BASE÷ in the code:
Recursion
Due to the limited size of the return stack of the HP-42S I assume that recursion doesn't really work.
Scope of Variables
The same variable name can be used local to a procedure but these are still mapped to global registers.
Cf. examples/scope.pl0
[attachment=13175]
The Language PL/0
program = block "." .
block = ["CONST" ident "=" number {"," ident "=" number} ";"]
["VAR" ident {"," ident} ";"]
{"PROCEDURE" ident ";" block ";"} statement.
statement = [ident ":=" expression | "CALL" ident |
"?" ident | "!" expression |
"BEGIN" statement {";" statement} "END" |
"IF" condition "THEN" statement |
"WHILE" condition "DO" statement] .
condition = "ODD" expression |
expression ("=" | "#" | "<" | "<=" | ">" | ">=") expression .
expression = ["+" | "-"] term {("+" | "-") term} .
term = factor {("*" | "/") factor} .
factor = ident | number | "(" expression ")" .
Download Project
Archive: pl0-compiler.zip
Length Date Time Name
3427 01-14-2024 14:50 pl0_lexer.py
12754 01-14-2024 14:52 pl0_parser.py
4393 01-14-2024 12:04 pl0_node_visitor.py
5141 01-14-2024 14:48 pl0_interpreter.py
6240 01-14-2024 14:52 pl0_compiler.py
5860 01-14-2024 14:50 pl0_hp42s.py
347 01-14-2024 13:53 examples/combination.pl0
153 01-14-2024 11:05 examples/constants.pl0
328 01-14-2024 11:05 examples/fibonacci.pl0
232 01-14-2024 12:51 examples/gcd.pl0
133 01-14-2024 15:07 examples/multiply.pl0
265 01-14-2024 13:42 examples/permutation.pl0
234 01-14-2024 11:05 examples/scope.pl0
232 01-14-2024 11:05 examples/square.pl0
39739 14 files
pip install ply
Programs
Fibonacci
# This program calculates the first K values of the fibonacci sequence.
CONST K = 20;
VAR m, n, k, count;
m := 1;
n := 1;
k := 1;
count := 0;
WHILE count <= K DO
! k;
k := n;
n := m + n;
m := k;
count := count + 1
END
END.
Compile to HP-42S
GTO 00 # main
# Register 01: m
# Register 02: n
# Register 03: k
# Register 04: count
LBL 00 # main
1
STO 01 # m
1
STO 02 # n
1
STO 03 # k
0
STO 04 # count
LBL 01 # while loop
20
RCL 04 # count
X>Y?
GTO 02 # end while loop if true
RCL 03 # k
PROMPT
RCL 02 # n
STO 03 # k
RCL 01 # m
RCL 02 # n
STO 02 # n
RCL 03 # k
STO 01 # m
RCL 04 # count
1
STO 04 # count
GTO 01 # loop again
LBL 02 # end while loop
END # main
Caveat
Input Output
Syntax
Integer Division
elif term[0] == "DIVIDE":
print("÷")
Recursion
Scope of Variables
[attachment=13175]
