Fibonacci Sequence
Initialisation
DSP 0
CLR
STO M
1
Loop
M+
x<>y
Result
0.
1.
1.
2.
3.
5.
8.
13.
21.
34.
Explanation
\begin{aligned}
x_{0} &= 0 \\
x_{1} &= 1 \\
x_{n+1} &= x_{n} + x_{n-1} \\
\end{aligned}
Python Program
a, b = 0, 1
for k in range(10):
print(a)
a, b = b, a + b
References
Viète's formula for \(\pi\)
Initialisation
DSP 9
0.5
STO K
CLR
STO M
2
ENTER
ENTER
ENTER
Loop
x<>y
M+
K
yx
STO M
Result
2.000000000
2.828427125
3.061467459
3.121445152
3.136548491
3.140331157
3.141277251
3.141513801
3.141572940
3.141587725
3.141591422
3.141592346
3.141592577
3.141592634
3.141592649
3.141592652
3.141592653
3.141592654
3.141592654
Explanation
\pi = 2 \cdot \frac{2}{\sqrt{2}} \cdot \frac{2}{\sqrt{2 + \sqrt{2}}} \cdot \frac{2}{\sqrt{2 + \sqrt{2 + \sqrt{2}}}} \cdots
Python Program
from math import sqrt
p, q = 2, 0
for k in range(20):
print(f"{p:>.9f}")
q = sqrt(2 + q)
p *= 2 / q
References
Can you guess the result?
- Can you come up with other interesting recipes?
Here's another one:
Euler's number
Initialisation
DSP 9
-1
STO K
13
STO M
1
ENTER
ENTER
ENTER
Loop
K
M+
Result
1.000000000
1.083333333
1.098484848
1.109848485
1.123316498
1.140414562
1.162916366
1.193819394
1.238763879
1.309690970
1.436563657
1.718281828
2.718281828
Explanation
\begin{aligned}
e
&= 1+{\frac {1}{1}}+{\frac {1}{1\cdot 2}}+{\frac {1}{1\cdot 2\cdot 3}}+\cdots \\
&= 1 + \frac{1}{1}\left(1 + \frac{1}{2}\left(1 + \frac{1}{3}\left(1 + \cdots \right) \right) \right) \\
\end{aligned}
Python Program
s = 0
for k in range(13, 0, -1):
s = 1 + s / k
print(f"{s:>.9f}")
References
I hope you realise in time when you have to stop.
Natural Logarithm
Example
\log(1.2) = \log(1 + 0.2) \approx 0.182321557
Initialisation
DSP 9
-1
STO K
0.2
ENTER
ENTER
ENTER
11
STO M
Loop
1
K
M+
x<>y
Result
0.018181818
0.016363636
0.018949495
0.021210101
0.024329408
0.028467452
0.034306510
0.043138698
0.058038927
0.088392215
0.182321557
Explanation
\begin{aligned}
\log(1+x)
&= x-{\frac {x^{2}}{2}}+{\frac {x^{3}}{3}} - \cdots \\
&= x \cdot \left(\frac{1}{1} - x \cdot \left(\frac{1}{2} - x \cdot \left(\frac{1}{3} - \cdots \right) \right) \right)
\end{aligned}
Python Program
x = 0.2
s = 0
for k in range(11, 0, -1):
s = x * (1 / k - s)
print(f"{s:>.9f}")
References
