12-26-2023, 08:38 PM
The first program listed here finds the basic solution to the Pellian equations
x^2 - d*y^2 = 1 or x^2 - d*y^2 = -1. To solve for the negative equation, enter
d as a negative number. For d to be a valid argument for the negative equation,
the repeating part of the continued fraction for the square root of d must be
of odd length. See A031396 and A003814. If d is a square or if d is negative but not
a valid argument, the trivial solution {1 0} is returned.
This program is inspired by a program by Bob Pulluard in Datafile V19N1,
available on the HHC thumb drive and from Jake Schwartz's PPC Archive.
This program uses a completely different algorithm based on convergents to the square root of d.
It is larger but at least 10 times as fast. The program requires the LongFloat Library because
the computations can require very high precision, up to thousands of digits.
The maximum size of d is limited by the amount of available memory, or the
patience of the user. The largest value that I have solved for is 1026061,
which requires over 7 hours on the physical 50g. The x value returned is
a 2555 digit number. See A033316 for values of d whose solutions are increasingly large.
Some notes on the theory of operation:
The basis of the program is the observation that solutions of the Pellian
equation for d are a subset of the convergents to the square root of d.
After determining that d is neither a square (invalid argument) nor 1 plus a
square (x = floor(sqrt(d)), y = 1), LongFloat functions are used to generate
a list of the repeating part of the continued fraction for the square root d.
If the length of the repeating part is odd, there is a solution for the
negative equation. This solution can be found in about half the time of the
solution for the positive equation, so this is done, and the positive
solution is computed from the negative solution if required.
The main loop of the program computes the convergents from the terms
of the continued fraction, and tests them until a solution is found. This is similar
to my recent Convergents program here. If the negative solution was computed and
the positive solution wanted, the former is converted to the latter.
The second program returns a list of solutions to the Pellian equation.
It assumes the existence of a variable called PELIAN containing the program above.
Given integers d on level 2 and n on level 1, returns list of the first n
solutions for x^2 - d*y^2 = 1 if d is positive, or x^2 - d*y^2 = -1 if
d is negative. Once the basic solution is found by PELIAN, the subsequent
solutions can be computed by a simple recurrence. Therefor the program is
very fast, although large values of d and/or n will quickly overflow memory.
If d is a square or if d is negative but not a valid argument, a list of n
copies of the trivial solution {1 0} is returned.
@ Given integer d on the stack, returns the basic solution to the Pellian
@ equation x^2 - d*y^2 = 1 if d is positive, or x^2 - d*y^2 = -1 if d is
@ negative and if the length of the repeating part of the continued fraction
@ for sqrt(d) is odd. Requires LongFloat.
@ Local variables
@ d: absolute value of d
@ b: sign of d
@ c: repeating part of continued fraction for sqrt(d)
@ n: length of c
@ a: -1 if d has solution for -1 else 1
@ s: maximum length of loop, also used to exit loop
@ k: looping variable
\<< DUP ABS DUP ROT SIGN \-> d b @ Save absolute value and sign
\<< @ Negative means solve for -1
IF DUP ZSqrt @ Is d a square?
THEN DROP2 { 1 0 } @ Then return trivial solution
ELSE DROP
IF DUP 1 - ZSqrt @ Is d 1 plus a square?
THEN NIP 1 b 1 SAME @ Return basic solution for -1
ELSE 2 * DUP @ 2 * floor(sqrt(d))
IF PICK3 I\->R 8940. \<= @ If d <= 8940
THEN 20 MAX @ At least 20 digit precision
ELSE 3 * 2 / @ 1.5 * precision for large d
END 'DIGITS' STO @ Store precision for LongFloat
SWAP FSQRT Fl\->SF SF\->CF @ Continued fraction for sqrt(d)
DUP ROT POS 1. SWAP SUB @ List up to end of repeating part
DUP HEAD SWAP TAIL @ Separate head
DUP SIZE DUP 2. MOD @ Parity of length of repeating part
IF DUP NOT b -1 SAME AND @ Even length but solving for -1
THEN DROP2 DROP2 1 0 0. @ Invalid d for -1
ELSE -1 1 IFTE 4. ALOG \-> c n a s @ Save local variables
\<< c 1. GET @ Get second CF term
1 SWAP PICK3 OVER * 1 + SWAP @ First two convergents
1. s @ Loop to generate and test conv's
FOR k c k n MOD 1. + GET @ Get next term modulo length of c
PICK3 OVER * 6. ROLL + @ Next numerator
PICK3 ROT * 5. ROLL + @ Next denominator
OVER SQ OVER SQ d * - a SAME @ Is this convergent a solution?
s 1. IFTE @ Exit loop if true
STEP ROT DROP ROT DROP @ Drop previous convergent
b 1 SAME a -1 SAME AND @ Flag for converting -1 solution
END
END { OVER SQ 2 * 1 + UNROT * 2 * @ Convert -1 solution to +1
} IFT 2. \->LIST @ Save as list
END
@ Given d on level 2 and n on level 1, returns list of the first n solutions
@ for x^2 - d*y^2 = 1 if d is positive, or x^2 - d*y^2 = -1 if
@ d is negative. d must be in A031396 to return a valid result for -1.
\<< OVER PELIAN DUP { 1 0 }
IF SAME @ If not a valid argument
THEN ROT DROP SWAP NDUPN \->LIST @ Return list of {1 0}
ELSE ROT SIGN UNROT @ Save real n and
SWAP I\->R 0 \-> n m @ dummy value for m
\<< DUP 1. GET @ x value to compute coefficient
IF ROT 1 SAME @ Solving for +1?
THEN 2 * 'm' STO @ Then 2*x
{ 1 0 } SWAP @ Starting list for recurrence
ELSE SQ 4 * 2 + 'm' STO @ 4*x^2 + 2
DUP { -1 1 } * SWAP @ Negate x for starting list
END 2. n @ Start main loop
START DUP m * PICK3 -
NEXT n \->LIST NIP @ Save list and remove starting list.
END
